Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Rear brake pad replacement question
Old Feb 24, 2015 | 04:12 PM
Rev19's Avatar
So my rear brakes have been squealing like the rear pads need replaced. I read some tutorials and checked out the how to article "HOW TO: Brake Rotors and Pads Replacement" seemed easy enough for a simple pad swap.
https://www.evolutionm.net/forums/ev...placement.html
So I put the car in gear, make sure e brake is off, remove wheel/jack up car. Those 2 pins holding the pads in wont budge. I'm using a cold rolled steel punch and a hammer. Its actually put an indent in the end of the punch being neither pin is budging. These are the original pads, so im sure these pins have never been removed. Is there something im doing wrong? Any idea's tips?
these are the rear brakes on a 2010 evo gsr
Old Feb 25, 2015 | 01:15 PM
hispanicpanic's Avatar
make sure the pin is of the proper diameter and you are hitting the pin and not the caliper. My pins have dents in them but i've changed pads about 3 times.
Old Feb 25, 2015 | 06:13 PM
2x4's Avatar
2x4
After my first pad change I bought the brembo brake pad pin punch. Much easier the second time around with this tool.
Old Mar 2, 2015 | 09:33 AM
search reveals this.
http://forums.racingbrake.com/showthread.php?p=5501
THough a proper sized punch will get you there with the same amount of effort.
nytalonTSi
Jul 24, 2012 08:48 AM
MitsuJoe
16
Apr 16, 2011 09:09 PM
Girodisc Martin
EvoX 'For Sale' Suspension / Brakes / Handling
59
Sep 24, 2008 08:37 AM
Evo8Master
Apr 10, 2006 09:39 AM
4-BNGR
Feb 28, 2005 12:33 PM
