Revalved Bilstein/Swift Spec R ???s
Hey Guys, haven't posted much but decided on a suspension set up that meets my needs for the right price.
Found a shop still revalving Bilstein struts for a reasonable price now that Bilstein has quit (pm if you want details), and am pairing them with Swift Spec R springs.
That being said, I'm trying to shore up any gaps in my knowledge. Is anything required outside of front camber bolts and lower control arms in the back to be able to adjust camber and maintain suspension geometry?
Is an RCK required/recommended at that level of drop? What about endlinks (stock sways for now)? And is any cutting required of the bump stops?
Thanks in advance guys, and please let me know if I need to consider anything else (other than harsh ride ha!).
RCK is always recommended for lowered car. The car comes with 2 position camber bolts up front. I would skip aftermarket ones and get camber plates, they can be had for about $300 and will be full adjustable. Or set your stock camber bolts for the higher (more negative) camber setting and if it's within a few tenths left-right, I would just run it. No need for end links on stock sways. You shouldn't need to cut bump stops. I would also look into the rear trailing arm busing, and the front control arm rear bushing.
Are you decided on the Swift Spec R's? Spec-R's are a good off the shelf spring for stock bilsteins, but if you are going to have custom valving, why not get the spring rates you want. GTworx could likely get you any spring rate, and height, springs you want for the same price. http://www.gtworx.com/
If GTworx can't source you the spring rates you want (which I suspect they can), try these guys http://www.fatcatmotorsports.com/ They have plenty of experience revalving bilsteins and pairing them with custom spring rates.
Nazarite (Mar 11, 2016)
Well right but there spring rates are pretty low and prolly would have been fine on stock shocks. But I guess I was thinking from a handling perspective you would want a much higher spring rate, but I guess I don't really know what your intention is lol, either way good luck!
Swift Spec-R are F: 6.4 kg/mm R: 6.8 kg/mm (which is pretty soft for the track)
http://www.swiftsprings.net/products...ct/spec-r.html
I have a hard time believing that someone (Tein/Eibach/Hyperco/Robispec) doesnt offer something stiffer that will fit the stock bilsteins.
LateBraking
17
Mar 15, 2015 05:55 PM
93gc8jdm
Dec 24, 2014 02:31 PM
markpaco
Jun 22, 2013 03:18 PM
CrAwLiN3vO
14
Jun 26, 2011 06:02 PM
Solo II Evo
13
Apr 15, 2009 07:00 PM
