Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Vibration at high speed?
Old Aug 11, 2017 | 06:36 AM
kyoo's Avatar
? are you using aftermarket lug nuts? if not, that's probably the cause
Old Aug 11, 2017 | 05:21 PM
PaulyX's Avatar
I am actually. Will the stock lugs fit the wheels?
Old Aug 13, 2017 | 08:46 PM
kyoo's Avatar
no, just checking. it needs those conical 60deg lugs
Old Aug 18, 2017 | 12:39 PM
thanman99's Avatar
most likely just unbalenced. This is the issue 99% of the time. if they set up the machine wrong they wont know until you go back and complain.
Goodluck to ya!
Old Feb 26, 2018 | 03:02 AM
auronle's Avatar
Try plastic hub ring
Old Mar 4, 2018 | 07:04 AM
EVOLx86's Avatar
I've had the same issue for a while. After inspection, every shop gave me the same answer the tires are unbalanced. Funny thing is both places didnt fix the issues after rebalancing.
mj0917
Aug 31, 2014 12:32 PM
RA2013
Jul 1, 2013 12:33 PM
MR White
14
Mar 3, 2013 10:21 AM
guest49582
May 31, 2011 10:13 AM
bluemm
22
Jan 28, 2008 09:20 PM
