Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
ABS Service Required
Old Apr 28, 2018 | 04:54 PM
JackJensen's Avatar
Hello all. I’m a new Evo owner and member of the site. I was looking for some clarity on how to solve a problem. My ABS and ASC OFF lights are on and the middle of my display says “SERVICE REQUIRED”. I’ve tried pulling the fuses, disconnecting the negative battery cable, and resetting the service notifications on the dash. I smell the brakes rubbing on the back tires and have no idea what to do.
Please help!
Old Apr 29, 2018 | 05:08 AM
Hi Jack
Hey, Im no ABS expert. I own the EVORS which is ABS delete
I would attempt an OBDII download & see if it reads the ABS fault. There is no doubt there is an active fault, just not sure if the OBDII picks up
that system. I will search around for that answer
Joe
Edit: Heres a thread that should shed some light. A standard OBD reader may not do it, but the thread offers up suggestions
https://www.evolutionm.net/forums/ev...ce-lights.html
Old Apr 29, 2018 | 11:17 AM
JackJensen's Avatar
I have a standard OBDII reader and hooked up to no avail, sadly. I’ll rummage through the link. Thank you for the help!
Old Jul 17, 2018 | 10:54 PM
Revox's Avatar
Did you ever get your ABS issue sorted out?
Old Jul 23, 2018 | 09:58 AM
JackJensen's Avatar
Yes, i wound up taking it to a tuner a couple hours from my house. He said the ETAC was bad and had to order a new one. He says now he has to take it to a Mitsubishi dealership and have them program it for my VIN. I’ll update whether or not it drives different when i get it back. I’s been gone since shortly after this post was made.
drew08
31
Sep 2, 2021 03:59 AM
alsong2002
Jul 13, 2017 11:40 AM
daasca
May 16, 2016 05:08 PM
Dboey
Dec 27, 2009 06:10 AM
PoWeRaCeRz
Jan 27, 2004 09:40 PM
