Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
What is the best TPMS solution nowadays?
Old May 14, 2018 | 06:42 AM
oblivionis's Avatar
When I bought my 2010 Evo it came without TPMS sensors. I'm looking to add those back. I'll only have one set of wheels. What is the best way to go? OEM, part # 4250B668 or is there a newer one? Or the VDO SE10001HP REDI-Sensor that is sold on Amazon? Or something else entirely? Thanks for the help.
Old May 20, 2018 | 11:44 PM
LetsGetThisDone's Avatar
Discount tire has sensors in stock that work just fine. When I worked there we installed them for free with purchase. Since you don't currently have sensors, make sure they rebalance the assembly after installing the sensor.
Old May 21, 2018 | 07:03 AM
oblivionis's Avatar
Good to know. Thanks.
Old May 21, 2018 | 05:50 PM
Warpath's Avatar
You can also use ETACS to turn off your tpms sensors. That's what I did
Old Sep 6, 2018 | 01:49 PM
oblivionis's Avatar
Just to update this thread, I ended up buying the VDO SE10001HP REDI-Sensor 314.9 MHZ/315 MHz TPMS sensors from Amazon. Pep Boys programmed them to the car in under 10 minutes without any problems. Total cost $116.
Old Oct 23, 2018 | 10:19 AM
FAC_Brian's Avatar
Have you heard of bluetooth sensors available now a days? can be monitored and controlled through an app on the phone.
Old Oct 29, 2018 | 04:48 PM
chinoxmk22's Avatar
same. the damn thing is so annoying to have when you switch to a new wheel set up .
evoul18
Sep 26, 2016 06:43 AM
LordCthulu
Mar 1, 2016 03:25 PM
