EvoM Announcements Discuss our latest site announcements.
[Road///Race Article] US Lancer Spring Installation
Old Nov 30, 2002 | 07:55 AM
KK's Avatar
KK
EvoM Administrator
Exclamation [Road///Race Article] US Lancer Spring Installation
Our latest article, by Gabriel Torres of Road///Race Motorsports, takes you step by step through the installation of a set of aftermarket springs. Not only does he cover the step by step install, but he also explains the differences between the two major brands available and what each requires. This is definately worth reading.
Read the article now!
Old Nov 30, 2002 | 08:43 AM
ryancb's Avatar
another reason why road///race
Old Nov 30, 2002 | 09:24 AM
swhskenr's Avatar
thank you road race.. I have been holding off on ordering the springs until i saw instructions. i even requested installation instructions in every "spring" related forum.. all of a sudden.. there they are!
Old Nov 30, 2002 | 10:07 AM
ROCK's Avatar
We have been wanting to do it for a while. I have been too busy. Besides, Gabriel has installed dozens of springs on Lancers. He is the expert!
ROAD/RACE
http://www.roadracemotorsports.com/
Old Nov 30, 2002 | 10:51 AM
norcallancer's Avatar
So Rock, how much would it be for you guys to install either eibach of progress springs. Also, how much to install Tein Suspension Kit?
Old Nov 30, 2002 | 11:18 AM
ROCK's Avatar
Figure about $140 for install!
ROAD/RACE
Old Nov 30, 2002 | 07:18 PM
majin's Avatar
to Road///Race
Old Nov 30, 2002 | 08:26 PM
nyclancer's Avatar
**** i read the instructions, i dunno if I would trust myself doing it!
Old Nov 30, 2002 | 10:00 PM
ryancb's Avatar
hey rob only thing didnt really say is how to get the bolt holding spring in off
Old Dec 3, 2002 | 01:00 PM
$140 for install. Sounds great. I'm gonna try and make it down there after Christmas, Rock. Probably sometime in January or February.
Old Dec 4, 2002 | 12:11 AM
eslai's Avatar
Heh, Gabriel did a good job on that one, Rob. His English is almost as good as Mike's.
Old Dec 29, 2002 | 10:45 PM
Alchemist's Avatar
I just did my install- got done about an hour ago. The article is excellent and all of the directions are accurate. I encourage everyone to find an impact wrench to help loosen all of the factory tightened nuts and to spin the nut off of the top of the struts.
There are only a few additions that I have:
1) remember that you have to loosen the lug nuts while the car is still on the ground (doh!) and then you can take the tires off while your car is in the air.
2) Remove the brakeline from the strut first. It makes using the impact wrench in there easier.
3) When you're aligning the strut after reassembly you can turn the plate that fits through the strut tower. No need to worry about it until its going back in place; when you need to align the bolts with their holes. Keep in mind that one of the three has to be in the same direction as the lower strut mounts.
4) On the rear Progress springs the narrow part goes on top. They mislabeled mine, so it was good that I did them one at a time and made sure that the new matched the old.
b) It's really hard to tell on the front springs which side is "UP" If yours are like mine, the sticker will be on the bottom (yep, had to tear it down a second time to fix the pop that was coming from my fronts).
5) I can't stress this enough- install your new sway bar AFTER you do your springs. What a friggin headache. Better yet, since there are only two nuts holding the swar bar in place take them off.
That's about it. I love the new ride quality and she drives like she's on rails. Thanks Gabriel!!
Old Sep 27, 2003 | 03:32 PM
yellozlancer's Avatar
Can you follow the same directions for coilovers?
k3lv
131
Aug 25, 2007 03:39 PM
ROCK
Mar 7, 2006 06:16 PM
KK
EvoM Announcements
30
Dec 31, 2003 11:27 AM
TeamSlamDotCom
Lancer Vendor Classifieds
15
Sep 19, 2003 10:39 PM
