NewB question from not so NewB
Old Feb 20, 2005 | 12:54 PM
UT_Evo's Avatar
Ok, so first off yeah, I realize I have more than 500 posts, and second, I tried searching, the damn search tool sucks major in finding EXACTLY what you want... anyway, this could or could not be a really stupid question... but:
How much hp is gained per pound of boost? Or rather, from 15psi = what hp? to ~18psi = what hp? to 20-21 = what hp? Any way anyone can answer this question, I'd really like to know... a good way to phrase the why I'm asking is: "what's the point of setting a mbc from 18 up to 20, assuming there already is an MBC set to 18 on the car"
Old Feb 20, 2005 | 01:22 PM
UT_Evo's Avatar
bump, someone's gotta have an answer?
Old Feb 20, 2005 | 01:43 PM
UT_Evo's Avatar
bump.... no one? is it that hard of a question?
Old Feb 20, 2005 | 01:49 PM
UT_Evo's Avatar
bump bump... I gotta know the answer
Old Feb 20, 2005 | 01:58 PM
DDDEVO's Avatar
Question
UT, I will give it my best shot. If I can remember, there was a post about this, not sure how long ago, but it has been a few months. If my memory serves me good, 1lb. of boost is equal to roughly 5-7 horsepower, if I remember correctly. Don't have a mbc yet, but I think a mbc holds boost a little better w/o tapering as much, but not sure. Hope this helps you out.
Old Feb 20, 2005 | 02:02 PM
UT_Evo's Avatar
That works out perfectly, thanks, after my turboback the stock boost solenoid is running the car at 15psi, so I didn't gain ANY power, and I should be up ~20 hp... so that all makes sense, thanks much
Old Feb 20, 2005 | 02:10 PM
feriosi'evotwin's Avatar
20 psi sounds nice its should be at 20 psi at every rpm ur hp will be raised up 10% from ur original hp
Old Feb 20, 2005 | 02:14 PM
UT_Evo's Avatar
What original? from stock? Huh?
Old Feb 22, 2005 | 08:20 PM
BlkEvo8AMS's Avatar
ur only holding 15psi??? sounds like a problem i had, the stock vacum lines may be damaged or too long, you should be at least holding 19.5 down to 16.5 stock
Old Feb 22, 2005 | 08:24 PM
UT_Evo's Avatar
It's the stock boost solenoid, but maybe I'll have mitsu check it out when I go in for 15k... just in case it's not 100% the stock solenoid
Curt@MrLed's Avatar
Former Vendor
with all the probs i keep seeing with these manual boost cont. people need to save some money and buy a good electronic one... i have had my hks evc for a year and a half and have not had a single prob..
Old Feb 23, 2005 | 05:43 AM
marky7's Avatar
no one posted for a while because no one understood what u were saying.
Old Feb 23, 2005 | 05:54 AM
UT_Evo's Avatar
How can you not understand the question of how much power more boost gives? A ton of people have gone from stock to higher... I figured people would know
