Problem with low boost
Old Feb 17, 2006 | 02:18 AM
Evil EV0's Avatar
Fran...Thats good to see your getting it tuned. Let us know the outcome. I hope you get it all figured out, maybe you can get a vid in against your S2K
BTW...Who's "Quik"
Old Feb 17, 2006 | 07:05 AM
fransevo's Avatar
Warr,
I think you are right on as usual. The guys I am going to for the low boost have seen the car before, the only thing is they haven't seen it since the cams/cam gears. I did some research on the AMS sight and it may have the stage 3 kit on it. I took off the cam gear cover and the cam gears are the Fidanza ones, they are set at 0. I am going to call AMS and see if they remember that car, there isn't too many around here. BTW the car has AMS stickers on the side and the fuel rail and injectors are AMS, hopefully they will be able to help out.
Old Feb 20, 2006 | 08:24 AM
fransevo's Avatar
The boost problem was fixed, Thanks Chad (Dieman motorsports)! Now I need to send in the ECU for reflash. I pulled it last night and I am sending it to Dynoflash tomorrow. Is Fedex the best way? He said he flashes and resends the same day .
Old Feb 20, 2006 | 09:13 AM
Warrtalon's Avatar
Yes, Fedex it overnight, and he will flash then overnight it back tomorrow.
So, what was causing the boost problem?
Old Feb 20, 2006 | 02:00 PM
Evil EV0's Avatar
^ +1? what was causing the low boost? Make sure to incklude a list of your mods with your ECU, man once you get it flashed your gonna love it.
Old Dec 14, 2006 | 03:41 PM
Sweaty Balls's Avatar
Low Boost over here too.
How was it fixed? I was boosting okay when I had the MBC on. I'm returning the car to stock in order to trade it in. With the stock setup, I can only boost 12-13 psi. Any ideas? The car was bought used in the first place can could never boost pass 12 psi w/o the MBC.
Thanks
Old Dec 14, 2006 | 04:17 PM
BretTheJet26's Avatar
i had the same problem, i bought a car at the dealership and was only boosting 11psi, i fixed it once i put the mbc on (6 months later)
i just think whoever the person prior to owning my car just swapped in some vac lines and called it a day. Dont you need mitsu lines for everything to work properly?
Old Dec 14, 2006 | 04:20 PM
4WS Tuning's Avatar
if your not using an MBC/EBC and using the stock setup it will NOT work properly unless you have the little metal beads in the line... so you have 2 choices... go buy new lines from mitsubishi.. i think theyre like 15-20$ not 100% since i ahvent needed them myself...
or ya go to napa get a few feet of vacuum hose and a mbc/ebc and let that up directly bypassing the stock unit.
CHEERS!
Old Dec 14, 2006 | 07:31 PM
https://www.evolutionm.net/forums/sh...ight=low+boost
Originally Posted by timzcat
There is a restrictor in the hose that goes from the T to the Discharge pipe. If you changed this vacuum hose you will only get 9-11 psi of boost. Your only fix is to restore the restriction or get an MBC.
The short hose from the T to compressor hosing/discharge tube had a restrictor in it. .....
Originally Posted by RalliArtEvoVIII
... IF the previous owner had a MBC, he might've put back the old lines but forgot the boost pill on the compressor side (theres 2 pills, 1 near the boost solenoid and 1 in the line that runs from the tee to the compressor nipple....
https://www.evolutionm.net/forums/sh...d.php?t=131475
Originally Posted by WHTEVO
what i would do if i was you is check the stock vacuum lines that go to the turbo, wastegate, and the boost control solenoid. just take off your intake and there is a brass thing with two nipples coming out of it that connect to the vacuum hoses i mentioned earlier. the solenoid will be screwed onto the big brass brass colored bracket under the stock intake box. there should be two metal reducers in the vacuum lines. one going to the turbo and the wastegate. you can feel them if you squeeze the lines. if both of them are out this is your problem. with both of those "pills" out you will get very low boost. check this out and let us know what you find. good luck.
I'll check that out.
jaredh
Apr 9, 2013 07:25 PM
SSickLS1
Sep 1, 2011 10:43 PM
Joe's Evo X
Apr 9, 2008 07:16 PM
tjordan06
Jan 23, 2008 08:06 PM
EvoDaWayToGo
13
Apr 9, 2003 10:33 AM
