SAFC II install and now... half idle??????
I know this is a common subject covered with the SAFC install but mine is not a product of inproper install.
The resources that I used were.....http://www.evotuners.net/forums/showthread.php?t=111
does anyone have an idea of why my car (according to the SAFC) is idling at 440rpm
when the factory gauge clearly says a little under 1000rpm.....
settings: Karman, 4cyl, throttle up and to the right.
any help would be greatly appreciated.
Thanks, Brandon
Thanks, Brandon
The only thing that I can say is to check all the connections again and make sure they are right. Maybe there is something wrong with S-AFC. If the stock tach shows normal idle and the car is idling just fine then it has to be something with the AFC. I know there have bee several times when I hookes something up and it didn't work right and I was so sure that I didn't everything by the book only to find I missed some small detail.
Did you tap the right wire for RPM? The EvoTuners write-up used to say pin 58, but then it was revised to say pin 88, I believe. If you didn't see that note at the bottom, you have may have done it wrong. Usually, though, when you see half rpm, that's because of having the cylinders set wrongly.
silverstream
10
Apr 20, 2007 02:07 PM
tokeone
Jan 13, 2005 03:34 PM
EvolutionRey
Jul 28, 2003 12:39 PM
