A\C Fan Grinding Noise
Old Jan 9, 2007 | 08:30 AM
GOTBOOST1023's Avatar
I've Been A Member For A Little Bit But This Is My First Post. Any Input Would Be Helpful. I Have An 05 Mr.
Has Anybody Had Any Problems With Their A\C Fan. When The Heat On It Sounds Like The Motor Is Grinding. It Only Does It For A Minute And Then It Stops. It Doesn't Affect The Way The Car Drives, It's Just Annoying. Its The Fan In Front Of The Radiator. I Don't Know If I Should Take It To The Dealer Because I Have Some Mods.
Old Jan 9, 2007 | 09:27 AM
Ph3n1x's Avatar
Prolly touching ur Icp. common
Old Jan 9, 2007 | 11:13 AM
I Dont See It Hitting Anything And I Never Changed The UICP
Old Jan 9, 2007 | 12:04 PM
TylerDurdenIX's Avatar
I had that issue with a tightening clamp where the fan on the engine side hit the bolt. Its not a big issue, nothing to really worry about.
Old Jan 10, 2007 | 08:02 AM
barneyb's Avatar
Do you mean under the hood or the cabin fan?
Old Jan 10, 2007 | 04:23 PM
under the hood.
Old Jan 10, 2007 | 04:25 PM
ak47po's Avatar
Has Anybody Had Any Problems With Their A\C Fan. When The Heat On It Sounds Like The Motor Is Grinding. It Only Does It For A Minute And Then It Stops. It Doesn't Affect The Way The Car Drives, It's Just Annoying. Its The Fan In Front Of The Radiator]. I Don't Know If I Should Take It To The Dealer Because I Have Some Mods.
Read
Old Jan 11, 2007 | 01:24 PM
barneyb's Avatar
Originally Posted by ak47po
Read
Sorry, I read. I also noticed it is winter outside so not much need for A/C. With heat the A/C fan only operates in defrost mode.
The cabin fan is noted for running dry of lubricant and squealing and this is an easy fix. So, just to make sure the owner wasn't hearing the cabin fan I asked again.
Old Jan 30, 2007 | 01:12 PM
Sorry it took so long for me to get back. It is the a/c fan under the hood. The one between the grille and radiator. It does do it when my defroster is on when it is raining. It's not the cabin fan.
araz5260
Feb 19, 2017 09:18 AM
lghtngyello03
10
Jul 22, 2016 03:26 PM
jdmEviL8
Northwest Region
16
Mar 15, 2012 07:43 PM
meckert
Aug 25, 2011 06:20 PM
EVO8LTW
Nov 1, 2009 08:36 AM
