TBE questions
Old Jun 6, 2007 | 04:09 PM
rediddy69's Avatar
TBE questions
I have a couple of TBE questions. My current setup is a jun b.l 3" catback exhaust. I am def upgrading both the downpipe and o2 housing. My question is would you suggest going to a test pipe or a high flow cat? I know the test pipe will give me more power but i will sacrifice driveability (sound). Also if anyone has any good suggestions for combos with those three parts that would be great too.
Thanks
Old Jun 6, 2007 | 04:17 PM
lizzys6/4's Avatar
well with a test pipe you will not pass emissions. if you are in a state where you have them, you might want to think about that.
Old Jun 6, 2007 | 04:22 PM
1GGEvo's Avatar
+1
More power but the main sacrifice is that you wont pass emissions
Old Jun 6, 2007 | 04:25 PM
groove304's Avatar
You also have the choice of a resonated test pipe. It will give you a more civil sound. I have one and I get absolutely no droning at any rpm.
MuslimEvoFreak's Avatar
If you don't mind removing your test pipe everytime you to for emissions and reinstall your cat then go for it. I don't believe you get that much power from the test pipe. My suggestion would be a high flow cat.
Old Jun 6, 2007 | 09:38 PM
rediddy69's Avatar
does anyone know off the top of their head the difference between a high flow cat a resonated test pipe and a test pipe I would assume this is the order in ascending order of power but to what degree?
Thanks
Old Jun 6, 2007 | 09:54 PM
Bash's Avatar
-Test pipe is just a 3" pipe that replaces cat, straight pipe
-resonated TP is a Test pipe that has a resonator to muffle the sound but does not reduce flow
-High flow cat allows greater flow without sacrificing emissions
In the order top is highest power
SilentSage32
Dec 31, 2010 02:38 PM
dorian7
Dec 9, 2008 01:48 PM
joedr
21
Aug 23, 2007 08:27 PM
XI OV3
15
Apr 19, 2007 08:21 PM
ultraist
May 30, 2006 12:45 PM
