To TBE or not to TBE that is the Question
Old Jul 2, 2007 | 08:11 PM
steevo's Avatar
I say research quiet exhuast systems with and get a HFC. No worries there.
Old Jul 2, 2007 | 08:15 PM
ducker's Avatar
TBE makes the car so much more enjoyable!
Old Jul 3, 2007 | 04:04 AM
Evol.ved's Avatar
I am going to be the disent opinon here.
Keep it stock. It's ALMOST as fast as a modifed car with an intact warrenty. Who doesn't know that the bolts are all painted so mitsu can tell if they have been removed?
Maybe just get a flash that will eliminate the factory crap tune and get you that majority of the power of a TBE without the noise.
Old Jul 3, 2007 | 05:28 AM
ovekcots's Avatar
Will the check engine light come on with the TBE
And if so, can I leave it on or should do something to turn it off
Old Jul 3, 2007 | 05:29 AM
ovekcots's Avatar
Is the TBEloud even at idle or normal driving?
Old Jul 3, 2007 | 05:39 AM
Kaido's Avatar
Depends on which one you get, as long as you avoid N1 style exhausts with no resonators you should be ok. If sound is big factor, look into a Fujitsubo, or Greddy SP2 exhaust, and use a high flow cat.
Old Jul 3, 2007 | 05:47 AM
ovekcots's Avatar
Tanabe Medalion Concept G Blue Full Turboback Exhaust
Old Jul 3, 2007 | 07:03 AM
Warrtalon's Avatar
Can you at least do 5 minutes of searching? This stuff should be in the Newbie forum...
Old Jul 3, 2007 | 09:12 AM
G20's Avatar
G20
I have 2, one with full exhaust no resonator and the other just a downpipe with HFC. It's depend on you, on the TBE car, it's loud but you feel raw and pump, basically you feel like driving. It could getting tire easily too after a while you may get a headache especilly in my place I have to keep looking around to make sure no popos around.
On the non-TBE, it's quiet, very quiet after switching back from the other car. Basically you fell like cruising and the car feel more expensive. It's also boring quickly. By the way, don't expect any aftermarket exhaust to be quiet like the stock one on both cruising and WOT.
So it's depend on that you want a life up and down like stock market or you want a flatliner one.
Old Jul 3, 2007 | 09:26 AM
CleverUserName's Avatar
Perrin TBE with Perrin HFC. Almost too quiet for what I wanted. I love it on the highway - no buzz, drone, resonance, or ear/headache. Plenty of personality when wide open on throttle. Sticks out far enough to not dirty your bumper. Fits like OEM. No cop problems so far.
So, yes, you really should. My old ebay exhaust got 24whp with the Perrin HFC and had better boost characteristics than stock.
Old Jul 3, 2007 | 09:31 AM
wyoevo's Avatar
I did the Tanabe TBE with cat delete and used the mechanical 02 sensor fix. I had the works flash, drop in filter and upgraded the clutch and flywheel. The car is much more fun and a good daily driver. No issues and I even have cruise control. I use the muffler insert to keep it quite but one bolt and it is out and loud if desired. I higly recommend it, better power and fuel economy. Will
Old Jul 3, 2007 | 02:52 PM
TxEvo8's Avatar
not even a question in my mind, do it!
Old Jul 3, 2007 | 05:47 PM
W0459732's Avatar
+1, TBE is awesome
Old Jul 3, 2007 | 05:52 PM
prj.evo's Avatar
JUN BL- super quiet/quality/power
Old Jul 3, 2007 | 06:05 PM
Turbo Kyle's Avatar
I love my Megan TBE. Its not loud at all till the gate opens
Verlassene
Mar 16, 2016 09:22 PM
RoryMarckese
10
Oct 21, 2010 07:32 AM
theboricua
May 12, 2009 04:02 PM
mrClean5
15
May 28, 2007 02:06 PM
monies41
15
Aug 27, 2006 07:55 AM
