TC/Diff/Clutch Fluid.
Old Oct 9, 2007 | 09:29 AM
FloopyDisk's Avatar
Been searching all morning my research has told me change regularly every 15K miles. Is this right? It has also recomended diaqueen for the fluids (OEM), is there any reason why they are better? (Was not able to find all this information when searching, sorry for the repost).
Also, main reason i want to change the clutch fluid is I get gear lock out on reserve and 2nd if I go to a high RPM in first. Is this the right course of action? or is this something with the bushings or syncros?
Thanks.
PS: We should probably sticky the correct information on this. Anyone with me on this? (If posted already, just reply with the link.)
Old Oct 9, 2007 | 09:36 AM
bluebyu36's Avatar
i use redline mt90 in my trany
redline heavy shock proof in my transfercase
Old Oct 9, 2007 | 11:00 AM
evo150's Avatar
are you still on the stock clutch? if so you may want to try adjusting your pedal and see if that helps http://evomoto.com/tech_info.php?tec...23acc502510fe1
Old Oct 9, 2007 | 11:03 AM
Cali2MDevo8's Avatar
Registered User
I would recommend to use all OEM fluid. Some people perform all fluid changes every 10-20K miles. This all depends on how hard you drive the car. I would think every 15K miles would be fine unless your tracking/running the car hard all the time.
Jason
Old Oct 9, 2007 | 11:49 AM
FloopyDisk's Avatar
Yes, I'm still on the stock clutch. I'll check it out. Thank you.
Old Oct 9, 2007 | 12:18 PM
newbieEVO8's Avatar
I had the same issue.
Adjusted the pedal and no more high rpm lock out.
g/l
Old Oct 9, 2007 | 12:26 PM
rcheung's Avatar
Thanks.
I change my tcase and rear diff fluid every 5K and tranny every 15k. The tcase fluid seems to need changing more often then the rest of the drivetrain.
Old Oct 9, 2007 | 01:06 PM
distant_02's Avatar
I just changed all fluids on sunday for the second time @ 30k on the clock. Used oem diaqueen for the t-case and rear. Redline MT90 in my tranny.
I change out my fluids @ 15k.
Slee256
17
Feb 22, 2012 07:11 PM
Pure Playaer
74
Nov 25, 2009 08:17 AM
shawn360h
14
Mar 27, 2009 09:07 AM
Jspec EVO VIII
Aug 27, 2007 09:05 AM
EvoDan2004
20
Jul 3, 2006 04:46 PM
