Boost Pill Location HELP
Old Apr 7, 2010 | 03:33 PM
fasfour's Avatar
I can't seem to find this information anywhere or even a pic with the proper setup. I went back to the stock boost control set up. Where I am confused and can't seem to find an answer is this. You have a line going from the wastegate to a "T" There is another line that goes from the "T" to a "nipple" on the hot pipe. Where is the boost pill supposed to be? Is it supposed to be from the "T" to the wastegate or in the section that goes to the "nipple" on the hot pipe off the turbo.
Thanks!!
Old Apr 8, 2010 | 07:41 PM
GSArgg's Avatar
Hey man,
Go to here and then go down to any stages that say "May require boost control system changes" and click the instruction. download the pdf and look at the pics they have for removing the pill
Hope this helps
Old Apr 10, 2010 | 12:09 PM
fasfour's Avatar
Thanks
Old Apr 10, 2010 | 12:32 PM
Boosted Tuning's Avatar
EDIT: Never mind. Thought this thread was about EVO 8/9, not EVO X.
Old Apr 17, 2010 | 10:35 AM
GSArgg's Avatar
We you able to get the B.Pill out ok?
Old Apr 17, 2010 | 12:57 PM
fasfour's Avatar
^^ I actually didn't need to get the boost pill out...I wasn't sure which side it went on. If it was the compressor side or the wastegate side. Through the great help of people on this forum...I found out it goes on the compressor side...which would make since because with the pill on the wastegate side it was only boosting 12-14 psi. Now it is a happy 17 to 20psi
Old Apr 24, 2010 | 10:43 PM
4G63kevin's Avatar
I'm planning to stay on stage 1 with the Cobb AP and is it necessary for me to remove the stock boost pill? I might need help too. lol
Old Apr 26, 2010 | 10:36 AM
fasfour's Avatar
^ Stage 1 you don't need to remove the pill. If you go stage 2 they recommend taking out the pill that is off the solenoid. If you go to cobbs site they have a pdf that shows you exactly which one to take out.
Flyhigh
Aug 12, 2025 09:51 AM
drb
53
Oct 25, 2016 07:50 AM
Casey Robertson
Jan 29, 2016 03:59 PM
wrcwannabe
Jun 21, 2007 04:51 PM
