New Owner EVO 9 already a problem, help!!
Old May 31, 2010, 08:52 AM
kousayee's Avatar
i just bought 06 EVO with 53000, the axle seal was leaking and caused a freak accident. the oil was dripping on the down pipe and the car caught on fire, luckily i extinguished it fast but damage already happened. the fire melted the wiring harness, tried to rewire my self but still car will start but if i touch the gas pedal it will cut off.
to make a long story short , i took to dealership and already replaced egr sensor and wires, throttle position sensor, acd ecu and front ecu and still cant get communication to ecu.
i am in disbelief, didnt even drive the car for a day and all that happened.
ok now is the question. is an axle seal covered under warranty? if it is what about all the damage that happened because of it.
please help my bill already at $2000 and cant get the car running
thanks for all the help in advance
Old May 31, 2010, 08:59 AM
evo unknown's Avatar
Are there any modifications done to the car? I believe 2006 Evo warranties are to 100k miles, but you would have to check on that. You can call Mitsu headquarters and retrieve your warranty information with your VIN number.
Old May 31, 2010, 09:12 AM
kousayee's Avatar
the car has k&n cone filter, other than that it is stock
Old May 31, 2010, 09:57 AM
jy951's Avatar
I thought the 06 100kl warranty is only for the original purchaser. Otherwise its the 5year/60k
Old May 31, 2010, 12:00 PM
akeric's Avatar
5yr/60k for all owners beyond first.
Old May 31, 2010, 12:25 PM
kousayee's Avatar
so is the axle seal covered under warranty??
Old May 31, 2010, 12:26 PM
lude2evo's Avatar
wait so even if i bought my car from another dealership my car still is under warranty from mitsu???
Old May 31, 2010, 12:39 PM
awdturbo8's Avatar
^^^ yes. I was the second owner of mine with 18k and I got all 4 new calipers and headlights covered under warranty due to the calipers fading when I sprayed wheel cleaner on them and
my headlights wouldn't adjust up or down. My rear diff started to chatter because it had the wrong fluid when I bought the car and they also replaced it. I got pretty damn lucky
Old May 31, 2010, 02:04 PM
lude2evo's Avatar
interesting, my pass headlight is from a base(even though im mr) and doesnt adjust . i wonder if theyd cover that. it was the only thing i hated about the ar
GRUSS
Feb 20, 2017 09:22 PM
Evo_Goodness
Jan 24, 2017 06:54 AM
stunna2o1
Jan 25, 2016 07:02 PM
hooliganSKATE
Dec 24, 2015 01:57 PM
cl271
Aug 23, 2015 12:32 AM
Quick Reply: New Owner EVO 9 already a problem, help!!
