MAP 2.4L pistons problems with Turbo Tuff Rods
Old Oct 27, 2010, 01:43 AM
ezz-e's Avatar
Are the map spec 2.4l pistons made for a specific rod or can any 4g63 rod be used. the reason i ask is because i was installing some alum rods into my 4g64 engine build and they would lock up when i tried to spin just one rod. I pull the rod of and check with one of my turbo tuff rods and they would also lock up?
Old Oct 27, 2010, 01:50 AM
RSMike's Avatar
you should really be asking ChrisCarey from Maperformance...
www.maperformance.com
Old Oct 27, 2010, 08:16 AM
ezz-e's Avatar
If some one from map could please step in and give me a answer that would be great
Old Oct 27, 2010, 08:18 AM
aka.ralliart15's Avatar
calling is easier they answer everytime
Old Oct 27, 2010, 08:32 AM
Bramage_Dained's Avatar
... and if you get put on hold instead of elevator music it's the theme music from nintendo games.
Old Oct 27, 2010, 12:04 PM
ezz-e's Avatar
bump
Old Oct 27, 2010, 12:09 PM
rawkus's Avatar
Really!? Why don't you call or at least email?
adam@maperformance.com
chris@maperformance.com
Better than waiting around for someone that may or may not be right answering your question.
Dan
Old Oct 27, 2010, 12:24 PM
Anarchy99's Avatar
Did you pin fit the rods to the pistons? There are a lot of newbies that think you can build an engine by taking pistons and rods out of a box and bolt it all together. That is far from the truth. There is quite a bunch of professional measurement and machining required to set clearances appropriately.
Old Oct 27, 2010, 01:47 PM
ezz-e's Avatar
I already contacted MAP two people there gave me two different answers. Any other 2.4l masters out there that can chime in?
I no i should have jus stayed 2.0L..... sigh
Not a newbie buddy... ASE Certified Tech here.
your question relates to piston and rod assembly not Rod clearance.
How about some helpful input next time.
Old Oct 27, 2010, 04:19 PM
3gEclipseTurbo's Avatar
Your asking about pistons when your question is more rod related. What length are the rods?
Old Oct 27, 2010, 05:14 PM
Teal2nnr's Avatar
He said he tried two different types of rods....same issue..
Old Oct 27, 2010, 06:15 PM
And your point? Pistons wont effect rods clearing the block.
Old Oct 27, 2010, 06:20 PM
94AWDcoupe's Avatar
both those rods are pretty beefy near rod bearing. there will be one cylinder where the rod comes too close to oil gallery. in you case it is hitting. simply grind in that spot on the block till you have .040 clearance.
Old Oct 28, 2010, 04:02 AM
GregGSC's Avatar
where is it hitting to cause it to lock up?. skirt, above the wrist pin, side of the block?
the Turbo tuff manley should spin over just fine. it actually has one of the smallest small ends out there (on the bottom bellow the wrist pin).
Old Oct 28, 2010, 07:14 AM
ghammer2's Avatar
totally calling just to be on hold....
Quick Reply: MAP 2.4L pistons problems with Turbo Tuff Rods
