brake pad change question
Old Nov 1, 2010 | 07:27 PM
shrty10135's Avatar
Ok i need to just change my pads on my evo 9 from what i believe are hawk pads that are way worn. i think im changing to EBC red stuff, but do i need new shims? or just pads, (im not very savy with brakes)
Old Nov 1, 2010 | 07:29 PM
EvoHung's Avatar
Definitely get the shims too.
Old Nov 1, 2010 | 07:53 PM
shrty10135's Avatar
What shims do I buy? Why do I need them?
Old Nov 1, 2010 | 08:27 PM
fantrman's Avatar
I don't have experience with EVOs - Yet, but I do know about brakes. Brake pads seem to be very subjective. They all have different cf fiction at different temperatures. How do you plan to use the car? Just street? Autocross? Drag? For just street, Porterfield R4-S are great. Little dust and lots of fiction. For autocross, Hawks are good although they make lots of dust and noise, especially the HP+. I tried the Hawk HPS, but did not like them at all. I had them on my M3 for two weeks and sent them back. No bite. EBC Red Stuff would be fine for only street, but the R4-S are a better dual-purpose pad - in my opinion.
Old Nov 2, 2010 | 03:50 PM
shrty10135's Avatar
oki chose to go with EBC red stuff, can i buy girodisc shims because idk if u can buy any brand shims? idk what they do and why they need to be changed so if im looking at getting EBS red stuff and girodisc shims would that be ok>?
Old Nov 3, 2010 | 06:45 AM
Davo's Avatar
the shims would work fine, once the shims are for the respective caliper, you would have no problem since all pad frames for the evo calipers are the same so another manufacturer's shim would work on another brand pad
Davo's Avatar
btw, give us a feedback on the redstuff when u can and what u repalced them with
Old Nov 3, 2010 | 08:03 AM
ElectrIX Blue's Avatar
Why do u need aftermarket shims in the first place?????? Why not reuse the oem one, just clean it up and you'll be good to go. Im using the same pads and running on stock shims and not a single squeal after 2k miles
Old Nov 3, 2010 | 08:11 AM
TxEvo8's Avatar
Use the OEM shims unless you are road racing, only then will you need to go Ti shims to help dissapate heat.
TxFAkuma
45
Feb 24, 2017 05:19 AM
okyu5632
Evo X How Tos / Installations
Sep 3, 2014 03:59 PM
OrangeMax
Northwest Region
19
Aug 29, 2013 05:57 PM
aguita
48
Nov 2, 2009 07:39 AM
riceball777
Feb 5, 2009 06:48 AM
