best oil when using the fp green?
Old Jan 4, 2011 | 12:17 PM
alex4g63's Avatar
hey guys just wondering whats the best oil i can put into my evo ix with an fp green... motor is not built and i have couple of bolt on parts
thanks
Old Jan 4, 2011 | 12:33 PM
ch1215g's Avatar
SUSPECTED SCAMMER
using Valvoline Racing Synthetic 10W-30 VR1 i would also like to know what others i can use, i know mobile 1 is a DEF NO!
Old Jan 4, 2011 | 12:40 PM
Kracka's Avatar
Nothing wrong with Mobil 1, it's a very good oil.
Old Jan 4, 2011 | 12:43 PM
gsrboi80's Avatar
Is everyone becoming brainwashed now My goodnees. Mobil 1 EP and the HM are both extremely good oils and can be had easily. Hell you'll never have an issue with the standard M1 but both the HM and EP have a better package
Do some research outside of EVOm.
Old Jan 4, 2011 | 12:48 PM
ch1215g's Avatar
SUSPECTED SCAMMER
FP did a test and couldnt find why all there fp greens were going bad, it was due to the oil (mobile 1) thats why from fp i was told not to use mobile 1 oil.
Old Jan 4, 2011 | 12:53 PM
JDM EVO PANAMA's Avatar
http://store.forcedperformance.net/m...otor%20Oil.pdf
There is the list buddy the ones highlighted in yellow are recommended and it seems like amsoil line has some of the best oils for the FP turbo
Old Jan 4, 2011 | 12:57 PM
gsrboi80's Avatar
Thought these only were Red and Black related failures as the greens use different bearing material that does not need the high zn and phos levels. If so ok add to the list another turbo I'll never own
Old Jan 4, 2011 | 12:59 PM
apagan01's Avatar
you are correct sir,, FP will void our turbo warranty if we use anything other than their approved oils.
look at FP's reccomendation from a standpoint of experience, they have seen more turbo failures than many others, and they discovered that what oils companies have been saying for years about high contents of ZDDP help with wear is correct and went ahead and addopted it into their process.
you will find in these forums a few that will swear by one oil, and are not willing to sit at the table and look at the data and weigh the posibilities of better oils for their engines,,,
I reccomend you look at the data on different oils, concentrate in synthetics with good reputation,
Old Jan 4, 2011 | 01:01 PM
Ghost1t's Avatar
Nice info , I also getting a Fp green soon and would like to know more about this
Old Jan 4, 2011 | 01:02 PM
alex4g63's Avatar
thanks
Old Jan 4, 2011 | 01:05 PM
ch1215g's Avatar
SUSPECTED SCAMMER
which amsoil do you recommend? im using the valvoline vr1 but i would like to switch to amsoil as it is easier to get around me.
Old Jan 4, 2011 | 01:08 PM
apagan01's Avatar
ch1215g,,, get the ATM 10w30 or the AMO 10W40 the 40 if you are planning on running the car a little harder at anything over 350 whp
Old Jan 4, 2011 | 01:09 PM
ch1215g's Avatar
SUSPECTED SCAMMER
im tuned at 367 whp so i should be getting the 10W40 looking to get into about 400-450 whp
Old Jan 4, 2011 | 01:13 PM
apagan01's Avatar
also look into RD 10W30 its a conservative 30 and would help you with cold starts.
Old Jan 4, 2011 | 01:18 PM
ch1215g's Avatar
SUSPECTED SCAMMER
RD 10W30? where can i find that?
