need help with clutch
Old Jul 19, 2012 | 10:46 AM
arcustoms's Avatar
the clutch in my evo 8 is going out, im looking for thoughts on a good clutch to run.
mods are
-upper and lower intercooling pipes
-255 fuel pump
-aem wideband
-boost gauge, volts, exauhst temp
-hallman mbc
-header
-3 in turbo back
-tien lowering springs
looking into turbo and injecters for next upgrades.
also a new fmic.
any ideas for me. thanks.
Old Jul 19, 2012 | 12:05 PM
hawaiianstyle's Avatar
You could run a stage one clutch since your around stock numbers. If you plan to beef up the HP then go with a stage 3 clutch. 6 puck clutch work good. Also depends on drivability, so if you want a smooth engaging clutch, get the exedy OEM clutch. If you want it to engage quick and firm then go stage 1 or higher and 6 puck. So it all depends on your needs and wants.
Old Jul 19, 2012 | 06:12 PM
arcustoms's Avatar
thanks that helps a lot, what about a sprung or unsprung?
Old Jul 19, 2012 | 06:45 PM
Get sprung. Clutch lasts longer I believe and doesn't bit as hard but you do loose a small amount of torque, but smoother and easier engaging.
Old Jul 20, 2012 | 03:34 AM
arcustoms's Avatar
Thanks for the help guys, this makes my choice a lot easier.
Old Jul 20, 2012 | 04:46 AM
FJF's Avatar
FJF
Heh, you're actually taking to just one guy.
Click Search ---> Advanced search ---> keyword: clutch ----> (choose) search thread titles on the Engine forum ----> 250 hits in 0.47seconds.
If you do this, you can read about clutches for days. FWIW, I run an HDSS on a ~300whp car and I don't dislike it. Good luck.
LancerShop.com
13
Sep 2, 2016 06:20 PM
zenoise
Midwest Region
Oct 7, 2012 06:43 PM
GST Motorsports
Mitsubishi TC-SST Discussion
20
Dec 22, 2011 01:54 AM
nhsean69
13
Sep 27, 2010 07:45 PM
Clue4488
29
Nov 28, 2009 03:38 AM
