plz plz plz help me.
it took me a long time to decide between evo and sti.. and evos seems to be more reliable and more fun to drive and better.. what i need help in is which evo is better? evo 8 or evo 9? and why? its my 1st evo so i really want to make it the best. thank you guys
what is your opinion?
Hm yeah that link isn't that useful then. IMO, 8 and 9 are identical, I would go by on what's the best deal you can find on what you're looking for (low/high miles, stock or built etc.) In the end it's just really up to you and what you plan to do with it.
But to answer your question I would suppose the 9 is a 'tad' bit better just because it's newer and some of the things they upgraded. Good luck
It really depends on your price range. The VIIIs seem to be a 5k cheaper in most cases. I think the IXs are better, not just because I have one, but because they are. The larger turbo and MIVEC makes a world of difference. Also the 05+ Evos have ACD which is awesome and help with traction, not to mention that the T-cases are a bit stronger. I'm still running the stock T-case in my car.
I will tell you that you should stay away from the MR. The 6-speeds tend to not hold up over 400+whp. I have the IX MR/SE which has the best performance and interior but the dumb 6-speed. So I put a 5-speed in my car.
What is your price range and we can help you find some decent cars for you. Make sure you look in the for sale section of the threads
Mikey
Mikey
8's are better drag cars cause of the no MIVEC
9's are better street cars because of the turbo and other little things.
the interiors are the same minus the fabric
basically if you plan on making over 600hp get an 8
if you have less than 17k to spend get an 8
if you dont fit into any of those categories get a 9
Mikey
I've had all three, VIII (3), IX (2), X(1) and I came back to a IX again. should be enough info. And VIIIs better for drag? C'mon! You can't beat the spool of mivec. At least on the stock frame turbos.
Evo9irvin
13
Sep 5, 2014 08:56 PM
Bega10
Dec 1, 2013 04:24 AM
