Harman Motive Evo X Products in Stock!
All Harman Motive Products in Stock and Shipping Now!
Harman Motive Evo X Intake System: $225
The Harman Motive Evo X Intake system offers significant improvements in horsepower, torque, and response. Developed on our Time Attack Evo X, our intake has proven dyno and track tested results. A simple bolt on modification you can install in your garage, our intake offers incredible bang for the buck and results you can feel and hear.
Features:
-One Piece Mandrel Bent Intake Pipe w/ Integrated MAF Housing (exclusive)
-Precision CNC Machined MAF Bracket
-All Fittings Professionally TIG Welded
-Polished to a Mirror Finish
-Ultra-High Quality Silicone Connectors
-Includes Bungs for Boost Solenoid and Crankcase at No Additional Charge!
-BOV Return Positioned for Smooth Return Flow
-AEM Dryflow Filter w/ Integrated Velocity Stack *Uses No Oil!*
-Includes all necessary clamps, hoses, fittings, and hardware
-100% Made in USA
-Super Detailed Instructions in the Box
Harman Motive Evo X Airbox: $149
Designed to work with our Evo X intake system, the Harman Motive airbox draws cold air from the factory intake scoop and protects your intake from engine bay temps. Our airbox drops intake temperatures 12 to 15 degrees at WOT when tested on our Mustang dyno. Unlike systems that place the filter in the fender, the Harman Motive intake and airbox won’t be exposed to puddles or road debris ensuring years of trouble free use.
Harman Motive Evo X UICP: $225
The Harman Motive Evo X UICP (Upper Intercooler Pipe) is designed to replace the rubber factory pipe while offering improved response and power. Made from 2.5" 6061 Aluminum and completely mandrel bent (no welds), our UICP offers great looks along with great performance. Unlike the stock piece, our UICP is 2.5" all the way from the turbo-outlet to the intercooler. Furthermore, our unit will not flex/expand like the stock rubber hose offering faster response you can feel!
Features:
-Bead-rolled Ends Designed for High Boost
-Fits with Stock Engine Cover and Radiator Shroud
-Factory-Style Support Bracket
-Ultra-High Quality Silicone Connectors (Replaces all stock connections - even the IC inlet!)
-100% Made in USA
Harman Motive Evo X Downpipe w/Cat: $399
Our downpipe replaces both the stock downpipe and stock cat pipe. This results in a lighter part with smoother bends and fewer connections. Our downpipe is 100% TIG welded stainless steel and is equipped with a 200-cell metal substrate catalytic converter for free flow up to 500whp.
Features:
-One piece design replaces factory downpipe and catpipe
- High-flow 200 cell metal substrate catalytic converter
- Full 304 SS construction
- 3" mandrel bent tubing
- 100% TIG welded - made in USA
- Uses Factory Donut Gasket for proper flex
Harman Motive Evo X Catback Exhaust: $549
The Harman Motive Evo X catback exhaust is a single muffler system. This reduces weight and provides the most direct path for exhaust. 100% TIG welded mandrel bent 3″ stainless steel with an 18″ resonator. Our system sounds great and looks great without being over the top.
Features:
- Single muffler design w/ 5" Tip
- Resonated
- Uses all factory hanger bushings
Harman Motive Turboback: $899 Savings of $50!
Features:
-100% Made in USA
Features:
-100% Made in USA
Features:
Features:
- Resonated
Hey does anyone know if you can run Harman Motive's LICP with there custom Air Box & Intake? I know competitors such as AMS state that you can't run the "STOCK" filter box with there LICP, so I thought maybe this might fall into the same issue. Is the size of Harman's Air Box smaller then stock, or is its location allowing of you to run Harmans Air Box with there LICP?
Any insight would help.
Thanks!
Thanks!
The AMS LICP differs because of how they bent it, it comes up sooner then bends into the TB for a straight shot which would hit the bottom of the air box. I think they are the only ones doing it that way so move other LICPs work with both factory and the Harman intake box. Since I have an MR and LICPs are not easy to find for us I'm not sure if this is true for the Harman LICP but I'm pretty sure it'll be fine.
