How does MR deserve a $4500 over EVO??
Old Feb 6, 2005 | 10:09 PM
  #241
nj1266's Avatar
Originally Posted by EVO Neil
If you are competing it is the difference between winning and loosing. Again, the Evo with the least amount of power was the quickest on the track. Besides you missed a major point of the article, it's not worth giving up the creature comforts when you can have you cake and eat it too with the MR. As far as acceleration with the MR being 95 pounds heavier than the RS and in this case also being down on power to the RS, it should have been slower. The weight difference will always be the same between the two but engine output is luck of the draw.
The MR is slower in a straight line. On the road course it is not. So the MR wins in one category and looses in another. I guess that makes them even especially when you consider that competition usually has a track segment and a drag segment. At least that what it had in your testing and every form of testing in a shootout. My point has ALWAYS been performance and not creature comfort. I never argued if the creature comfrots were worth it, I always said Perfromance. In this instance it is not worth it to spend $7000 and loose on the drag strip and win on a road course. $7000 should make the MR dominate in every category. It clearly does not.
It was more than just the wing, you are reading into the article what you want. It was most likely a combination of more downforce, better braking and better handling over the bumpy sections.
You do not know what it really is. It could be many things. Had you bothered to swap trunk lids and VG, then you could have eliminated these two variables. But you did not. With $7000 in my pocket I can easily upgrade the brakes, get a JIC suspension, slap on a wing and have money to spare for more mods. Yet you are still stuck with the same MR.
I believe if you look you'll see we posted two of the three runs. Look at the runs and you'll see that the MR on it's other run was a lot of power down compared to the other Evo's second runs.
I checked the web site and you only mention the numbers for one dyno run and not the others. Please tell me what are the ALL the dyno numbers if you have them. I will average them out myself.
Old Feb 6, 2005 | 10:13 PM
  #242
nj1266's Avatar
Originally Posted by Most-Wanted
nj1266 - Why are you fighting the value point? If it isn't for you, don't buy it. It may be for someone else Let it go, Mitsubishi has offered a different trim model, that's it.
I am arguing the PERFORMANCE point and not the value point. The performance that you get from the MR is not worth the extra $7000 over the RS.
Old Feb 6, 2005 | 10:30 PM
  #243
tujzr3496's Avatar
I agree 7 grand istn worth it. Sure the MR may be more comfortable, have a wing and w/e else, but its and EVO, who cares? The RS is fun and fast. enough said. RS over MR any day
Old Feb 6, 2005 | 11:25 PM
  #244
EFIxMR's Avatar
No car will produce the same dyno numbers run to run. Also what is the margin of error of that dyno?
As a professional dyno operator, I tell you that is false. Provided the engine isn't heat soaked, an engine that's properly tuned makes the same amount of hp with little margin variance.
The trap speed is almost the same 102 MR to 102.8 RS. That means that both cars have almost the same HP with the RS having a slight edge.
Neil has explicitly said that on the dyno the RS made more hp. The similar trap speeds of the MR despite being low on hp and up on weight, means it is using it's powerband more effectively.
The RS's brake problems are easily solved with race pads, Motul 600, and SS brake lines.
That's some bull**** right there. Even if you replace the pads, fluid and lines... the major part of brake locking is the tire. Also, changing the pads, fluid and lines... has little to do with lock up... That has a lot more to do with preventing brake fade.
but beside that point, are you gonna tell me the RS with minor brake mods can out brake an ABS MR in the rain? Road racing is rain or shine.
Old Feb 7, 2005 | 03:08 AM
  #245
MadMsheen's Avatar
I have found this thread to be amusing and educational. I spent valuable hours (that should have been spent studying) just reading through it. As far as whether or not the MR is worth the extra cash, being an MR owner, I would have to say "yes". I'm sure that MR owners would agree. And I think that MR owners are the most qualified to answer that question; we're the ones who spent the extra cash for it. We could have purchased an RS or straight VIII, but we chose the MR. Mitsu is offering three flavors of the Evo for a reason, to suit different tastes.
For those that have the intention of invalidating the purchase of an MR, I would recommend that you attempt to evaluate why someone would purchase one Evo as opposed to the other. And for that individual the purchase is justified. Before purchasing, I evaluated the pros and cons of each model, and the MR just happened to suit my taste best. I got it for MSRP -$500 for owner loyalty, and after reading this thread and many others like it, I still think it is worth the extra money. Quantifying the difference will not always be the best way to make a decision. Numbers aren't everything. We must take into account the all around feeling that comes with the purchases we make.
Thanks to JT for starting this thread (probably a few more like it). Thanks to EFI and EVO Neil. I am a member of evolutionmr.net (good info there) and I have an MT subscription (along with 4 other car mags I subscribe to). I very much enjoyed the "Is 22 feet worth $7000?" article. And thanks to NJ for his input into this thread, and possibly inspiring the MT article. And most of all, thanks to Mitsubishi for bringing the Evo to our shores, a great car in whatever trim you choose.
Old Feb 7, 2005 | 09:04 AM
  #246
SlowboyMR's Avatar
That was a perfect quote... i agree totally. I also have the MR and Love it.. so to me it was worth the extra money..
Mark
SBR
Old Feb 7, 2005 | 10:26 AM
  #247
JT-KGY's Avatar
Fine.. not tiny... but should have been wider..
Oh wait.. for a 3300lb car?? It is TINY!
You drove them back to back? Is your GSR an 05 as well?
The thread started comparing 05 Evo to 05 MR... I'm sure the 05 MR has "some"
obvious advantage over pre-05s...
Originally Posted by MR-SilverEVO8
Tiny? I love your sense of proportion
Well, basically the MR is a different car. If you drove them back to back you will experience the difference. Talking about it is useless. Anyway, no matter what, it still might not be worth it to you (sounds like your mind is made up anyway). I had the GSR and when I drove the MR I decided on the spot that the MR was well worth buying and I have not changed my mind.
Old Feb 7, 2005 | 11:44 AM
  #248
JT-KGY's Avatar
??? It is my problem.. It is my opinion...
and it's obvious that world doesn't revolve around me and my little 30k... look at
how fat every single new car is compare to the older model..
I never say people has to agree with me... merely asking if people feel the same
way like I do... I have to say there must be other hardcore performance guys
among Evo owners...
Anyways, I'm glad you find MR to your liking... and we'll probably see the direction
Mitsu is taking soon with Evo 9.
Originally Posted by favre95
JT you said this "NO, refinement didnt matter... at least NOT TO ME."
See that is your problem....you think in terms of yourself only! Mitsu doesn't think like that....they need something to appeal to the vast majority that are in the market fot this car. That statement is nothing more than the "kiddish" and "moronic" crap that circulates this board. I now see why the subie boards make fun of this site.
People for the most part want PW, PL, AC, radio, Sound dampening, and so on. To say that car makers need to strip their cars of these things to please a 1/2 percent (if that) of the automobile market is just retarded! Get over your ego dude, the world doesn't revolve around you or your 30 grand!
Look at it this way. Do you think the GSR is worth the extra money than the RS? It should, it has more refinements. Just as the Mr has more refinements than the GSR.
So please lose that attitude that your 30k is better than someone elses.
You also said this...."Thats the problem with today's car... none of them are focused (maybe except the Lotus Elise).. none of them could do one thing well.."
I beg to differ! If that is the case why did you buy an Evo?! On the same token....Why did you buy any car for that matter?! It seems nothing will please you and your "hard core performance" attitude. The evo in any form far exceeds any car in its price range(s) in terms of performance. Any magazine article will tell you that let alone any Evo owner.
Old Feb 7, 2005 | 02:21 PM
  #249
nj1266's Avatar
There will always be variance. It can be 1 hp, 2 hp or 0.5 hp, but there will always be variance. I write for Nissan Performance Magazine for the Spec V project and we have over 39 dyno runs on the car. We dyno three runs for every mod we put on the car. EVERY run varies from the other run. That is why I asked Neil for an AVERAGE of the three runs for each car. That is a far better indicator of the EVO hp than one run where the RS got 8 peak hp more than the MR. Furthermore, peak hp is not everything it is the area under the curve that each car has. Given the 6 speed vs. 5 speed I would like to see the MR dyno overlapped with the RS dyno.
There is a differnce of 0.8 mph in trap speed. Does that account for the 8hp difference in favor of the RS? Could it not mean that the 8 hp more gave the RS a 0.8 mph better trap speed? You should be able to answer that. How much hp does the EVO need to improve its trap speed by 0.8 mph?
Why is it that most club racers disable their ABS on the track? Could you please tell me? Changing pads, fluid, and lines will improve pedal feel and makes the brakes less prone to fade. Most of the club racers that I know do not have ABS on their cars.
Old Feb 7, 2005 | 02:23 PM
  #250
EFIxMR's Avatar
I don't mean to be a dick in some of these posts. Originally, I just posted the results of my MR in the EVO tuner challenge to show MR owners what their car was capable of stock vs. some of the best modified EVOs on the westcoast. I took my then brand new car to get flogged at willow springs, only to be criticized by Nj1266 (who at the time didn't even own an EVO). So, naturally I was just a bit defensive.
I have about 10,000 miles on my MR now, and I still love the car. 3 weeks ago, I had a great time with it at Buttonwillow raceway. I've driven fwd cars in various states of tune (from 130 whp to 400 whp) and some rwd cars (miata and nsx) on the same track previously, and none of those compare to the MR in terms of feeling comfortable/safe when driven at speed.
Old Feb 13, 2005 | 11:20 AM
  #251
mr-man's Avatar
Remember, the MR is a limited production car...give it 5 years, and there will be 500...
Old Feb 15, 2005 | 08:48 PM
  #252
Silver TT's Avatar
Originally Posted by Richard 350z
I understand that the MR 6-speed has the same ratios in 1st and 2nd gear so that the car can a keep low 0 - 60 mph time (without shifting into 3rd), and that 6th gear in the MR is the same as 5th gear an all other EVOs. They just scrunched down 3rd, 4th and 5th gears to cover the same ground that 3rd and 4th cover in other EVOs.
Can anyone who has driven both either confirm or deny this statement?
This is quite easy to confirm - if you are driving on the highway at 70 MPH and they are both at the same RPM - then both gear boxes have the same final gear ratio. As for gears 1 + 2 - that logic seems to make sense as well.
The main reason I would get the MR is for the 6 speed and the associated lower RPM driving and gas MPG savings. But if the final ratio is the same as the 5 speed then I don't see a real advantage in the 6 speed - particularly if you consider the added weight.
Old Feb 15, 2005 | 10:30 PM
  #253
EVO Neil's Avatar
Gear ratios and final drive ratios are different betwen the five and six-speed boxes.
Old Feb 15, 2005 | 10:35 PM
  #254
EVO Neil's Avatar
For those that say the MR finished first at the Streets of Willow because of the track configuration, let me add that when Mitsubishi goes to the NURBURGRING to set the record they take their best Evo, period! Do you think they may know a thing or two about which one is the best for setting records? They don't take the RS, because even though it is their "track" model it was primarily designed to be sold to racers, who would normally strip and modify it to meet the rules and requirements of whatever series they are racing in. That's why it is sold, that is it's main purpose for being offered. When the GSR was the top of the line, that's what they took to set the records, but now it's the MR. Why, advertising hype? Some may say, but it's because they gave the MR the best they had technologically. When they take the Evo IX to Nurburgring they'll take whatever version has the best chance for performing best.
Old Feb 15, 2005 | 10:45 PM
  #255
Speete's Avatar
If the US models came with Active Yaw Control it would have been another story. I've driven Euro models, worth it, and the 05 US edition MR, not really. The Euro cars are a different bird all together. The MR's are cool no doubt, but I'd stick with my none ACD Evo, which came with a vortex generator. Although its for sale now, so I'll have no Evo at all
