What could it be?
Old Mar 18, 2005 | 11:08 PM
  #31
Jakeg97's Avatar
Originally Posted by ezhangin
For some reason I thought AYC was only on the rear wheels
hmmm....
Old Mar 19, 2005 | 12:09 AM
  #32
Jakeg97's Avatar
*2: ACD (Active Center Differential)
The ACD incorporates an electronically controlled hydraulic multi-plate clutch. An ECU optimizes clutch cover clamp load for different driving conditions, regulating the differential limiting action between free and locked states. The result is improved steering response together with better traction. ACD provides three modes — Tarmac / Gravel / Snow — to enable quicker control response for changes in road surface. A single ECU provides integrated management of both ACD and Super AYC components.
*3: Super AYC (Active Yaw Control)
Mitsubishi's Active Yaw Control system uses a torque-transfer mechanism in the rear differential. Under ECU control, the system operates to raise cornering performance by transferring torque between the rear wheels as dictated by driving conditions and so control the yaw moment acting on the car body. In an evolutionary step, switching from the use of a bevel to a planetary gear differential gave Super AYC the ability to transfer almost twice the torque between the rear wheels. As well as reducing understeer further, it delivers LSD-level traction. The use of a single ECU to integrally manage Super AYC with the ACD results in a synergism that makes both components operate more effectively than if they were under independent control.
Old Mar 19, 2005 | 12:46 AM
  #33
astondg's Avatar
It is, where did I say that it wasn't? When I said shift power between wheels I meant the between each rear wheel.
Aston
Old Mar 19, 2005 | 12:56 AM
  #34
Jakeg97's Avatar
http://media.mitsubishi-motors.com/p...etail1228.html
https://www.evolutionm.net/forums/sh...d.php?t=125670
mitsuevodriver
Mar 22, 2010 03:45 PM
flip_EVO
Southeast Region
18
Mar 19, 2007 01:23 PM
biomedman
11
Mar 1, 2007 10:25 PM
Rallyman
15
Mar 22, 2006 07:21 AM
g35sammy
47
Mar 15, 2006 01:58 PM
