AWD Lancer GTS?
i will have to disagree with the unable to bounce the rev limiter statement, i was bouncing my rev limiter when i had it in manual, and my car did not upshift, until my crappy manual shifting came into play about a 1 1/2-2 seconds later. And besides that complaining about not being able to bounce a rev limiter is like saying u were disappointed because it wouldn't allow u to destroy the car. I mean honestly come on......if you wanna bounce your rev limiter go back to the honda forums because thats the cool thing to do there. But hey thats just my opinion.
The SST specifically addressed this issue by sending the signal to the SST on hard G forces to avoid up shifting when it would upset the car's balance. The Jetta I drove would upshift in the middle of a hard turn nearly 1000rpm from redline if you stopped flooring the throttle.
I'm done discussing this however. Thanks for assuming I'm an idiot wanting to bang the limiter to show off or something.
To end the argument, the ralliart has no use for a manual. The market is not in the performance minded consumer. Look at the commercials... It's for soccer moms who simply want a little more power out of there family car. So why would soccer mom want a stick? Performance minded consumers are Evo. They font need to make a stick ralliart. It's not a performance model.
what is the price of Lancer with 4WD in Japan? and wanted to known whether it is available in rear wheel drive.
The reason there isn't a 5 speed available on the RA is because it takes time and money to make it. Why would they spend time and money doing it if only a small percentage of people actually drive stick, with even a lower percentage buying the car.
Last I checked, this was an "AWD Lancer GTS" thread.
WTF happened to the original topic?!?!
(and how haven't the moderators sniffed this out after a month of the same old "stick vs. SST" OT crap?!)
Lancer *IS* available in 4wd, but in Japan only (or other country that sells JDM model)
http://www.mitsubishi-motors.co.jp/g...eup/index.html
WOW forget awd, check out the interior on that 'Super Exceed' model!
It's going to be called an SE and it will have a 2.4l. So for those that really wanted a Ralliart with a manual can just turbocharge the SE when it comes out.
RA012124
Outlander Sport
20
May 29, 2013 05:41 PM
hechtrod
Nov 29, 2007 08:07 PM
