MR 1/4 mile time...
Originally Posted by limey
I don't believe this subject....I don't understand wanting to purchase a vehicle that is leagues ahead of just about anything shy of six figures in the cornering/handling department and the big debate is how quick is it in the quarter mile?......a straight run
On the 03 Evo by far the most impressive qualties IMO is the chassis poise, the telepathic steering and the brakes all of which work a lot better on the MR but are not used on a dragstrip....what a waste
agreed. this car is wasted in the 1/4... well, not wasted... nevermind, it's wasted... blah to you all
Originally Posted by 3000ways
See that is what I figured, the 2005 USDM EVO GSR is also going to have 276HP, and I believe 300HP is a more correct figure for the 2005 USDM EVO MR. I mean look at the EVO FQ-340- 340HP/320TQ and the EVO FQ-300- 300HP/290-295TQ then all of a sudden the EVO MR sways from this formula with 276-280HP/295TQ doesn't make any sense, and I believe that the correct HP rating for the USA EVO MR will be 300HP with 295TQ. Hopefully dyno numbers will prove it.
remember that in Japan, it is illegal to produce more than 280bhp on a productuion car (well an unwritten law). So if people ask how much the Evo produces they just say...mmmm...............276bhp, when in actual fact they produce nearer 300. Look at the Skyline R34 GT-R...that thing is no way 280bhp
Ok I calculated the formula using a base 2004 EVO-
HP= 273 x 3500RPM/5252 and I get 181.9306, and that makes no sense, even if it is meant at the wheels, it's still low. Am I doing it correctly?
without a dyno graph it is hard to explain...
450lbs....bloody hell, do people weigh that much?!? I'm about 200lbs and consider myslef a fat ba$tard
Originally Posted by Nad1370
I think for every 50lbs. is a .10 off the 1/4
No, 100 lbs is .10 and 10 HP is .10. A misshift or slow shift can also cost you .3 though. At the end of the 1/4 .1 is about equal to a car length also, to give some perspective.
To you guys calling yourselves fat at 175 lbs or 200 lbs, ever heard of body fat percentage? You might be fat at 175 but at 190 I have very little fat. You can be 400 lbs and not fat. You are probably a really tall bodybuilder though.
Originally Posted by evoracer4lyfe
i think it's gonna hit about 12.8 and that's with perfect shifting
Yeah I believe the HP rating is only around 276-280, but the TQ has went up to 295. This brings up a question I have, how can HP go up so low but TQ go up so high, aren't the two inner-related, if TQ goes up by 22, wouldn't HP see the same or atleast close to same increase? Is the MR HP rating really underrated, I mean it has a bigger turbo, but only an increase of 5 to 9 HP
Depends on where the torque is made. Horsepower can be calculated if you know the torque and the engine rpm. Power is defined as how hard you push and how far you push in a given time. Torque would be how hard and rpm would be how far in a given time. Horsepower is usually the important factor, as long as the hp is not very peaky. Those who say things like torque wins races just are referring to a flat power band, but a car with just as flat a power band, that had less torque but made it at a higher rpm so it made more hp, would be faster. The reason is similar to the idea of a mechanical advantage or lever, but to get the point, you could use different gearing with the car that had less torque but at a higher rpm so that there would be greater torque at the wheels. Anyway, if the MR makes more torque at the place where it makes peak hp, then the hp peak will increase, if it makes more torque lower in the powerband, the peak hp will not increase. They must be not letting full boost stay on at high rpms, hence the torque drop causing a hp number that is less than the torque number.
The specs I saw for the MR were 285hp and 295 lb torque as rated in speed magazine for what thats worth. I also saw 12.8 seconds for the quarter mile and 4.8 for 0-60 time in more than one spec listing.
