More success with the UTEC!
Old Nov 16, 2004 | 08:18 AM
  #31
TampaTurbo's Avatar
Originally Posted by VTECH8TR
Mark,
This is what Flat foot shifting is
( a.k.a. Stutter Box, 2 Step, Anti-Lag )
We've all seen it at Drag Race meetings. A typical pro stock car pulls up to the christmas tree, stages and just as the lights start counting down the engine hits full noise seeming to bounce off a rev limiter. In fact, the driver has just pushed the throttle pedal absolutley flat to the floor and he doesn't lift off until the car passes the finish line because the engine has a launch control and flat shift system installed. Once a feature only available to professional race teams or those willing to install a $3,000+ after market engine management system.
Flat-Shift can eliminate those frustrating and sometimes embarrassing "bog downs" off the line by perfectly matching revs to your pre-set limit every single time. It also allows full boost to be retained on up shifts as your right foot never has to leave the floor because the Flat-Shift cuts engine power for the fraction of a second that you have the clutch pedal down meaning your engine has no time to bleed boost pressure between gears.
Thanks bro. Goodbye clutch.
Old Nov 16, 2004 | 08:20 AM
  #32
TampaTurbo's Avatar
Oh BTW you wouldnt want to leave it on all the time because it makes daily driving not fun.
Old Nov 16, 2004 | 08:30 AM
  #33
Spec C's Avatar
i used to set mine real low on my wrx and just flat foot shift every shift just driving normally around town..
Old Nov 16, 2004 | 08:47 AM
  #34
TampaTurbo's Avatar
Thats crazy but funny.
Old Nov 16, 2004 | 10:50 AM
  #35
SubiEvolved's Avatar
Thats funny cuz its true...
Old Nov 16, 2004 | 06:20 PM
  #36
justrick's Avatar
set it for 6500 -----inj cut-----my gt35 makes 14 pounds----launches are ballistic shifts revs are nicely matched ----i even mean the 1 to 2 shift is awesome and it tries to jump out of the tires.....clutches suck-----i like the smell... just remember to slip it...
Old Nov 28, 2004 | 06:56 PM
  #37
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Wink
Nice to meet you dude again I was at Island when you ran those times your ca is awesome and so is Sam's he listen when I pick up my ride in Jan you thnk you could give me some tips?
Old Nov 28, 2004 | 06:58 PM
  #38
Kwman's Avatar
Yeeehaw.
Old Nov 28, 2004 | 09:55 PM
  #39
no problem
Old Dec 4, 2004 | 12:25 AM
  #40
DBallz's Avatar
Cool cause I picked it up early we will be in contact hope to see you at car club one day
06rallyred
Sep 10, 2014 08:09 PM
unowned
Evo X Dyno Results
30
Feb 14, 2013 05:11 PM
dtrackstar
Nov 11, 2012 07:56 AM
MalibuJack
May 23, 2006 04:48 AM
