For anyone considering the AEM vs. Autronic...
Old Feb 4, 2006 | 08:24 AM
  #46
evolved69's Avatar
i have the aem unit and its work great for me so far...just make sure that you have someone tune it who knows what they are doing!!
Old Feb 23, 2006 | 03:27 PM
  #47
Flyin EVO 2's Avatar
Autronic has been making stand-alone ecu's specificly for Evo's since the Evo 1. I've seen many DSM's with AEM ecu's have strange random no- start issues as well as features not working correctly such as anti-lag or 2 step launch control. I know AEM has come a long way in working out a lot of bugs, but why even risk the hassle when Autronic's have over a decade of success. It definately helps to have someone who know's the Autronic unit to help you out, but with the purachse of a Autronic you get to join Autronics private forum, which Ray Hall (The head of Autronic) is moderator of. I've heard bad things about AEM customer support as well.
Old Feb 12, 2007 | 06:54 PM
  #48
diablo2184's Avatar
Originally Posted by WHTEVO
Sorry to bring back an old thread, but i want to know more. I am having a very hard time deciding between the AEM and the Autronic P&P. Would someone be so kind as to make a list of pros and cons between the two systems? I know this is in the Autronic forum so it might be biased a little.
x2
Old Feb 13, 2007 | 02:30 AM
  #49
quadcam's Avatar
Originally Posted by Flyin EVO 2
Autronic has been making stand-alone ecu's specificly for Evo's since the Evo 1. ....., which Ray Hall (The head of Autronic) is ...
Just to clear up a couple of misunderstandings,
IIRC the replacement boards started with Evo 5, but there was a evo 4 version shortly after with an extra mounting plate for the non plastic case of evo 4.
Ray Hall is the head of Ray Hall Turbocharging based in Cairns Australia, and does the bulk of the international distribution. The head of Autronic is Richard Aubert who does design / manufacture / etc.
The genuine Autronic design/manufactured boards are SM4, SM2, SMC and Evo 9 (3 plug, which includes 3 plug Evo 8), Subaru WRX 5 plug (2001-2005/6 depending on model), Subaru 3 plug (1999-2000) and Evo 4-8 4 plug.
Ray Hall makes some other base boards with an SM4 circuit board mounted on the base board. These boards are not supported by Richard Aubert as he does not have testers or circuit configurations for them.
Old Feb 14, 2007 | 11:42 PM
  #50
Hic's Avatar
Hic
just to add....ray's boards also work. these are fully functional sm4 boards with correct PNP connectors for some cars. it really saves you the time you need to do it yourself
Old May 10, 2007 | 06:49 PM
  #51
Max Power's Avatar
So, the evo 8 plug and play board does not have funtioning knock control? Does it log knock?
Old May 14, 2007 | 01:33 AM
  #52
Hic's Avatar
Hic
Autronic ECU's don't have knock log and knock control yet. It will be available very soon.
Why do yu need that? I KNOW that AEM knock "control" doesn't work....if it works, why do you destroy engines then?!?!?
Old Jan 18, 2008 | 10:36 PM
  #53
boostin06ggevo's Avatar
DynoFlash you should just relax. Autronic is the way to go. Aem has glitches and cold start problems like no other.
Old Jan 18, 2008 | 10:57 PM
  #54
ExViTermini's Avatar
actually the EMS knock control works very well, you just have to be sure its setup properly. Its a lot better than having nothing at all, thats for sho.
Old Jan 19, 2008 | 06:38 AM
  #55
diablo2184's Avatar
i think they new Autronics now have knock built-in correct? at least i heard that they were gonna bring that option out....can anyone advise?
Shaun@AWDMotorsports
EvoX 'For Sale' Interior Styling
133
Jun 14, 2016 10:35 AM
b16_rex
May 6, 2012 07:11 AM
MagicManRed
Oct 25, 2011 10:57 PM
tweakdsm
16
Nov 10, 2009 07:15 PM
TrinaBabe
12
Jul 7, 2005 09:32 PM
