keep getting fuel or boost cut?
if anyone could help that would be great. i got the car tuned a week ago. the guy set the boost cut on the utec at 22 psi. well if i hit it in 3rd usuall it will feel like the car slamed a wall. i am not sure if this is fuel cut or boost cut. my boost gauge is telling me it is holding right under 20psi so i dont see why the utec would cut boost. I also cant put the pedal down before like 4000rmps in any gear or it will do the same. maybe i have a bad mbc? any help would be great.
thanks, chris
thanks, chris
It could be overboost that your not picking up.. But if your using Open loop fueling its likely boost cut..
Here's the trouble, unless your logging the data, there's no real way to know for sure whats going on..
Anyway, I get that on occasion from a misfire, but it doesnt feel like I'm hitting a wall..
there is one MAJOR exception.. If your running an older firmware, or do not have Open loop fueling enabled, you will still be at the mercy of the stock fuel/boost cut and RPM limits.. so verify that OLF is enabled and that your running a v1.7 firmware
3303 +32.4 672 77 10 00 +8.4 29.2 Ecu. +5.0 500.00 856
3380 +32.6 746 100 10 00 +5.5 35.1 Ecu. +5.0 500.00 730
3479 +32.6 927 100 10 00 +4.4 43.7 Ecu. +5.0 500.00 965
3553 +32.4 843 100 20 00 -1.1 53.7 +6.5 +9.0 500.00 1162
3728 +32.4 1128 100 30 00 -2.2 57.7 +6.6 +9.0 500.00 1453
3921 +32.4 1121 100 40 00 -0.8 62.4 +6.9 +9.0 500.00 1131
4105 +32.4 1170 100 40 00 +1.7 60.0 +7.2 +9.0 500.00 1173
4171 +32.4 1144 100 40 00 +2.8 63.4 +7.5 +9.0 500.00 1381
4351 +32.4 1207 100 50 00 +1.8 63.9 +7.9 +9.0 500.00 1184
4474 +32.0 1222 100 50 00 +1.8 66.8 +7.9 +9.0 500.00 1302
4610 +32.0 1291 100 50 00 +3.1 68.9 +8.0 +9.0 500.00 1366
4810 +32.0 1275 100 50 00 +3.0 70.8 +8.2 +8.2 500.00 1552
4873 +32.0 1308 100 50 00 +3.9 75.2 +8.3 +7.0 500.00 1388
5027 +32.2 1396 100 60 00 +3.8 75.8 +8.5 +5.0 500.00 1562
5167 +32.2 1377 100 60 00 +3.8 76.5 +8.9 +5.0 500.00 1497
5291 +32.2 1440 100 60 00 +3.7 77.0 +9.2 +5.0 500.00 1543
5428 +32.2 1461 100 60 00 +3.7 78.9 +9.2 +5.0 500.00 1533
5583 +32.0 1449 100 70 00 +5.0 84.0 +9.6 +5.0 500.00 1533
5678 +32.0 1483 100 70 00 +5.1 88.1 +11.3 +5.0 500.00 1623
5963 +32.0 1552 100 70 00 +8.2 89.1 +12.8 +5.0 500.00 1602
6082 +31.8 1582 100 70 00 +9.1 91.9 +13.3 +5.4 500.00 1689
6161 +32.0 1607 100 80 00 +10.1 93.4 +13.8 +6.6 500.00 1552
6253 +32.2 1628 100 80 00 +10.2 96.3 +14.5 +7.0 500.00 1700
6385 +32.2 1618 100 80 00 +11.4 ---.- +15.4 +7.0 500.00 1736
6485 +32.4 1623 100 80 00 +11.3 ---.- +16.3 +7.0 500.00 1677
6626 +32.4 1633 100 80 00 +13.1 99.1 +16.4 +7.0 500.00 1724
6693 +32.2 1644 100 80 00 +13.5 ---.- +16.6 +7.0 500.00 1785
6816 +32.2 1666 100 80 00 +14.5 ---.- +16.8 +7.0 500.00 1760
6872 +32.2 1677 100 80 00 +15.6 ---.- +16.9 +7.0 500.00 1700
6973 +32.2 1672 100 90 00 +16.5 ---.- +17.0 +7.0 500.00 1908
7017 +32.4 1672 100 90 00 +16.4 ---.- +17.3 +7.0 500.00 1824
7122 +32.4 1677 100 90 00 +16.3 ---.- +17.5 +7.0 500.00 1838
7199 +32.4 1700 100 90 00 +17.5 ---.- +17.8 +7.0 500.00 1748
7278 +32.4 1689 100 90 00 +17.6 ---.- +18.2 +7.0 500.00 1851
7122 +32.4 261 22 00 00 +36.6 9.5 Ecu. +5.0 Ecu. 193
Are you using open loop fueling and closed loop boost? 500's in your boost table seems weird if you aren't using open loop fueling...
Anyway, not sure what --- means, but it looks like UTEC fuel cut.. (plus your maxxed on your injector duty)
1) What firmware are you running
2) Are you using open loop fueling
3) are you using closed loop boost?
4) Did you enable any of the boost cut or RPM cut features?
i have intake, tbe with out cat, walbralo 255, hard intercooler piping, 272i, 264e cams, utec, type s bov
the car was tuned by junior who used to work at turbotrix.
this is one of 2 maps he did on the car. the other has a little more agressive timing but the boost was set at 90 on the 2nd map. i think open loop fueling may come in at 35% throttle.
Originally Posted by calhoun
1. firmware is 1.7 (c)
2.its not running open loop fueling
3.yes running open loop boost
and he turned up my rev limiter but it still hits where stock is.
OK this makes alot more sense now..
YES your hitting fuel cut.. if Open loop fuel feature is turned off your at the mercy of the factory ECU's RPM and Boost/Fuel cut limits
if your using closed loop boost control (requiring those values of 500) you need a map sensor, if you don't have one, then you should disable it or it may behave strangely. (From what I can tell it looks like you do with your PSIA values, but since I didn't see them vary I can't be sure)
Yeah if your not using open loop fuel control, when you add fuel you basically increase the likely hood that the ECU will get fuel cut..
I actually have this happen to me every time I run my car in passthrough mode, I get fuel cut exactly at 4000rpm, occasionally I get a misfire that feels like stumbling, depends on the density of the air that day.. if its not very dense, I don't get the fuel cut, but I get the misfire.. therefore I rarely if ever run passthrough anymore.
ok i will go ahead and order a map sensor it was on my list, but why are the injectors maxing out? is it because i am not running open loop fuel? and if i do run open loop fueling will i still need larger injectors?
also i want to say thank you for your help, i appreciate all the time you spend on here helping others. thank you.
