Map sensor Calibration
Old Feb 3, 2005 | 09:26 PM
BSREVOLUTION's Avatar
i think i fixed my problem, i changed my map display from gauge to absolute, now my utec psi very close to my defi gauge.
im i correct in changing this?
Old Feb 3, 2005 | 09:32 PM
superman105's Avatar
can you explain me how do you come about your P1 and M1 number ??
Old Feb 3, 2005 | 09:33 PM
yep I did that too
Old Feb 3, 2005 | 09:36 PM
P1-head boost a 5psi
M1-at 5psi of boost, read map reading in logger 4.
Old Feb 3, 2005 | 09:37 PM
Originally Posted by superman105
yep I did that too
i cant believe that was my whole problem.
Old Feb 4, 2005 | 08:22 AM
Imprezd's Avatar
Ok, guys I have a generic calibration for the map sensor.
Gradient - 233
Intercept - 190
It's not that hard but what i have found was that alot of the guys who have been calling me for help their is definitely some innaccurate boost gauges out their.
Good Luck, I hope this helps.
Jermaine@turboxs.com
Old Feb 4, 2005 | 11:56 AM
yes thank you Jermaine for your feed back
just that the default setting on the Utec the Gardient value was lower than Intercept.
so I keep on thinking my calculation was wrong since my Gradient came out to be higher.
and I have notice right after you save the new value you have entered to the UTEC
you need to turn off the utec wait for 1 or 2 min and than restart the car
to show the correct value. otherwise it will always show a very high negative PSI number
Old Feb 5, 2005 | 11:32 AM
Imprezd's Avatar
The gradient is usually higher. Yes right after you enter the new value the map sensor has to take a barometric pressure reading in order to accurate. The values I just listed are for our map sensor. The default values in the UTEC are for the GM 3 Bar Map if i recall correctly.
Thanks,
Jermaine~
Old Feb 8, 2005 | 02:32 PM
i know is off topic, does everyones loads move smoothly? i mean, do the go 10-20-30-40... before the map sensor install, my loads were like this. now with the map sensor, my loads jump like 40-50-60-70-80-70-90. why is this?
Old Feb 10, 2005 | 07:21 PM
Map as a load reference will result in different load reference vs Maf as a load reference
Old Feb 10, 2005 | 07:37 PM
i guess i have to relearn tuning.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
1091x
Sep 12, 2017 10:49 AM
Benja
May 21, 2012 05:30 PM
philr8
Jul 24, 2010 05:02 PM
MysticMyth
Aug 4, 2004 10:44 AM
