Great $6.95 Shift Light
Old Mar 1, 2005 | 05:13 PM
EvoTech's Avatar
I bought this small LED light cluster from superbrightleds.com. I mounted it in my Craig Hardy dash panel and it works great. Even on a bright sunny day it really catches your attention. It comes 12V ready and works like a charm.I tried to take pics but the damn thing is so bright the camara could not compensate. http://www.superbrightleds.com/cgi-b...roduct=ACCENTS.
Old Mar 1, 2005 | 05:47 PM
dryad001's Avatar
Are the LED's all different colors?
Old Mar 1, 2005 | 06:03 PM
kekek's Avatar
What are you using to send the signal to the light?
^^Forget it...I didn't realize what forum I am in, I assume it is a user programmable output from the UTEC....
Old Mar 2, 2005 | 05:08 AM
EvoTech's Avatar
Yep
Old Mar 13, 2005 | 12:24 AM
BSREVOLUTION's Avatar
i just ordered my led, may you share how you set yours up?
Old Mar 13, 2005 | 12:47 AM
Lowness's Avatar
where did you mount it on the Craig Hardy panel? post a pic plz?
Old Mar 13, 2005 | 11:40 AM
Evoisdream's Avatar
yeah you should talk a lil bit more aobut how u have it set up got my utec and was considering picking one up also are the leds all the same color? thanks
evoisdream
Old Mar 13, 2005 | 02:43 PM
EvoTech's Avatar
The LED's are all blue, but the color is your choice. The pic sucks but it is all that I have. I plan on recessing it into the panel soon.
Old Mar 13, 2005 | 03:43 PM
Evoisdream's Avatar
i like it hrmmm i need to figure out how to hook one up to my utec..
Old Mar 13, 2005 | 03:54 PM
EvoTech's Avatar
The UTEC has 3 user defined outputs for shift lights. All you need is the molex connector, pins and 18 gauge wire.
Old Mar 13, 2005 | 08:51 PM
MalibuJack's Avatar
Yep.. you take a 12v source, through the light, then use the switched connections for "Ground" side of your light..
I find the bayonette lights work best, I have a regular shift light, but I also found these cheapo "lighting kit" lights with super bright LED's, basically map illumination that looks like tiny little shift lights, I happen to think they look pretty good too..
I happen to think these look alot like shift lights and are very bright..
Old Mar 13, 2005 | 09:10 PM
Evoisdream's Avatar
where did u find those lights from jack?
Old Mar 14, 2005 | 05:31 AM
EvoTech's Avatar
Be careful to read the specs on any LED that you choose. The light can not draw more than 100Ma or you risk burning out a section of the board on your UTEC. This is documented in the UTEC manual.
Old Mar 14, 2005 | 09:11 AM
gestalt, i will be okay with the 6.95 led? could you pm me what else i need to buy to have the led work? im just confused on where i plug the led into. thanks justin
Old Mar 14, 2005 | 09:51 AM
EvoTech's Avatar
The LED is powered by a 12V switched source. The Utec acts as the ground. There are three pins in the molex connector (see manual) for the remote map switch that are used as the grounds for the shift light. I am only using one shift point so I am only using one of these pins, but you can use all three for a sequential shift light if you want. Yes the $6.95 cluster pulls < 100Ma so it is fine and I have been using it with no problems. Look at the UTEC manual for which pins are for the shift light output (ground).
