View Poll Results: PLX or LM1
PLX
19
57.58%
LM1
14
42.42%
Voters: 33. You may not vote on this poll
PLX or LM1
Old Apr 8, 2005 | 07:43 AM
GOT EVO's Avatar
PLX can also be used with autronic autotune PLX has the best display for watching what your afr's are i have the M250 with 52mm gauge its the way to go
Old Apr 8, 2005 | 08:49 AM
MINES13's Avatar
The LM-1 and LC-1 both are capable of interfacing with the Autronic autotune function. Check out the Innovate forums people do it all the time.
Old May 12, 2005 | 02:25 PM
Gruppe-S's Avatar
The good thing about the PLX widebands is the size. Both the innovate and PLX will read AFR but PLX is about the size of a radar detector thefore you can mount it anywhere you want.
PLX vs other widebands:
1. Read <10AFR
2. faster response time 10Hz vs 3Hz
3. Cheaper replacement sensor
4. Compact size
5. Competitive pricing
6. Great technical support
Thanks,
Tom
Gruppes
510-783-5300
This is a new PLX Wideband (R500):
Its almost the same size as a Apexi SAFC and this will read EGT, AFR and Knock (3 in 1).
Key Features:
-Accurately measures Air/Fuel Ratio, EGT, and Knock
-Powerful 32 bit integrated processor, RAM, and FLASH technologies
-Integrated 6 Inputs for data logging (2 Speed, 4 Analog)
-Built-in amplifier for audible knock output to speakers or headphones
-Over 80 minutes of onboard memory
-4 analog outputs (User configurable)
-Fully customizable LED warning light or shift light
-High speed USB 2.0 interface
-Large dot matrix display with blue backlight
-100% backwards compatible with M-Series controllers
-Compact dash mountable design (4.75 x 2.25 x 1 inch)
-Sensor soft start circuitry, prolongs o2 sensor life
-Powerful PC analysis software included (PLX Logger Version 2.0+ Free Download)
-Field firmware upgradeable (more features added to R-500 regularly)
Introduction:
The R-500 combines 3 essential parameters (Air/Fuel, EGT, Knock) of internal combustion engine tuning into one! Whether you're on the dyno, track, autocross, street or drag strip, the R-500 can be fully customized to suite your individual application. With intuitive user menus packed with features, merged with powerful PC software, there is virtually nothing that the R-500 can't do.
Old May 12, 2005 | 05:59 PM
plokivos's Avatar
damn, repost on my repost.
https://www.evolutionm.net/forums/se...archid=1032095
especially this one.
https://www.evolutionm.net/forums/sh...light=plx+m300
Get them from Cal at Gruppe-s. Best price at Gruppe-s.
maperformance
Evo 'For Sale' Electronics / Lighting / Audio
1273
Jul 4, 2012 08:12 AM
philr8
May 10, 2010 08:21 AM
funks
For Sale - Miscellaneous Automotive
Oct 29, 2009 12:11 AM
xLaNcErEvOx
Oct 19, 2006 12:05 AM
hawaiian_evo
10
Jul 31, 2006 05:59 PM
