View Poll Results: PLX or LM1
PLX
19
57.58%
LM1
14
42.42%
Voters: 33. You may not vote on this poll
PLX or LM1
Old Mar 4, 2005 | 01:37 PM
josh930's Avatar
PLX or LM1
You guys would know better than my forum..... PLX or LM1 and why. Thanks
Old Mar 6, 2005 | 12:24 PM
GTVEVO's Avatar
PLX is my vote, why? Out standing support from them, fast shipping, cheap replacement sensor, Always trying to make improvements, Supported, tested and wizard, calibrated for the AEM EMS.
What is the update rate of the LM1? The PLX is about 10 times per second. You might have to ask yourself that question.
Note both are good products though.
Old Mar 7, 2005 | 05:03 PM
Mike W's Avatar
Neither. http://www.zeitronix.com
Calibrations are supplied for the EMS cal points.
Mike W
Old Mar 7, 2005 | 07:03 PM
Widebandphillip's Avatar
The lm-1 can customize its output calibration to whatever you want.
Old Mar 8, 2005 | 05:19 AM
Rollaway's Avatar
LM-1..... Reads exactly the same as the MoTeC system... and yes Tested it.... i dont have experience with the other brand except for the AEM Uego and the Uego's readings are off a bit
Old Mar 8, 2005 | 01:54 PM
Jokeri's Avatar
Lm-1 can be used with Autronic autotune
Old Mar 8, 2005 | 04:57 PM
josh930's Avatar
Does the plx replace the front oxygen sensor completely? Also, how much is the zetronics one?
Old Mar 8, 2005 | 08:37 PM
dsm95hybrid's Avatar
Zeitronix ZT2 is the way to go- listen to Mike Welch. His prices are as good as most group buys for this unit. www.roadraceengineering.com
Old Mar 11, 2005 | 12:27 AM
SSJ3GST's Avatar
I believe the PLX Wideband completely replaces the stock oxygen sensor.
Have you guys seen the new PLX R-500?
http://plxdevices.com/
What do you guys think?
Old Mar 14, 2005 | 09:32 PM
josh930's Avatar
The zetronics one looks like it also replaces the O2 sensor. Am I correct?
Old Mar 14, 2005 | 11:51 PM
Mike W's Avatar
Yes it can. They run from $279 to $400 to over $500 depending on display and logging options. But $279 can get you going.
Mike W
Old Mar 17, 2005 | 07:29 AM
Jorge T's Avatar
Mike W
I vote for zeitronix too! AFR, TPS, BOOST and EGT all in one
60+samples per second!!!
Old Mar 17, 2005 | 07:35 AM
kapolani's Avatar
When the time comes for me to start working on engine management - the Zeitronix unit is one of the first things I'm getting.
Old Mar 17, 2005 | 04:11 PM
josh930's Avatar
Good thing I posted this. I would have never found out about the zetronics, which is probably the one I'm going to get. Thanks.
Old Mar 29, 2005 | 06:04 PM
MINES13's Avatar
The LM-1 has a response time of 120ms and datalogs 12 times per second synchronous. It is faster then any other setup you can buy including the a Horiba which is 50 grand.
