Old Jun 1, 2005 | 10:41 PM
haze1995's Avatar
the gauge was tapped into the factory wiring harness (still is). Where to tap into next?
Old Jun 2, 2005 | 12:56 AM
ICE888's Avatar
Where you are should be correct. I would try taking it off and checking if the connection is good. That is all I can think of right now. I just dont think the UTEC will effect a low voltage reading input from the o2 sensor.
Alfred
Old Jun 2, 2005 | 06:15 AM
haze1995's Avatar
Thanks, turned out to be a loose wire. Problem fixed and everything is irking fine.
tevol1
14
Feb 17, 2010 10:30 PM
Vivid Racing
13
May 27, 2007 02:45 PM
gsujeff55
Apr 12, 2006 01:26 PM
Grog
Apr 30, 2005 06:06 AM
Illrunya
Mar 18, 2004 09:13 PM
