MAP sensor question...
Old Nov 1, 2007 | 11:32 AM
  #31
David Buschur's Avatar
I don't know where you can get a 3.5. I do have 4 bar map sensors for the Power FC, they are $225 each and I have the settings for the Power FC.
Old Nov 1, 2007 | 01:25 PM
  #32
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by RickyLee53
I couldn't find the sensors on the RX7 site, does anybody know where i can get a 3.5 bar map sensor from and the calibrations for the Power FC.
Buschur and RX7.com both have 4 Bar in stock and both have the calibration numbers for the PFC. I have confirmed this in the past week. Call either one and I'm sure they can help you out.
EDIT - Sorry, didn't see David's reply.
Old Nov 2, 2007 | 06:34 AM
  #33
RickyLee53's Avatar
I'm over in the UK, so will PM you now if thats ok .
Will the setting's you send me accurate or would i be better to program myself, bear in mind i'd need to go out and buy a vac pump.
Old Mar 19, 2010 | 03:42 PM
  #34
adcgn45's Avatar
zietronixs sells a 3.5 bar map
Old Mar 19, 2010 | 06:27 PM
  #35
adcqn45, your input is useless, sorry. You need the tendencies and offsets from Apexi to use any map sensor with their ECU.
Old Mar 19, 2010 | 07:14 PM
  #36
adcgn45's Avatar
oh didnt realize i was in the apexi section sorry i stumbled here looking for something.although im sure that its compatable
Old Mar 27, 2010 | 10:51 PM
  #37
arghx7's Avatar
You can use whatever MAP sensor you want really, you just have to calculate the scale and offset. There is a spreadsheet you can use to produce these numbers.
Brad1907
Feb 3, 2017 11:17 AM
boosted91t
Apr 15, 2016 07:48 AM
jameswwt
Sep 18, 2015 05:49 AM
shunderwunder
AEM EMS
Jun 14, 2008 07:06 PM
omtorlak
AEM EMS
Oct 2, 2007 11:03 PM
