Splicing Fields Harness?
Sorry I dont know if this has been covered. But my quick question is. Is it possible just to cut off the end of the fields harness that doesnt plug into the ECU and then connect the SAFC wires? Or should I just keep the other end on and splice into the harness? THanks for help.
You don't want to do that. Since your AFC reads input from the sensors of the car what you want to do is strip away the ...stripping...on the fields harness wires and splice (solder) the AFC wires into them. Kind of like shaving a strip of hair to tatoo an area. Also make sure you that you follow directions and theres a good pin out diagram and install how/to on evotuners.net
Thanks for help everybody. Understood.
5!grand!slam
Sep 13, 2006 02:30 AM
lynkz
19
Jun 9, 2004 08:34 PM
