Perrin Shortram and Boost tubes
Old Jul 26, 2005 | 05:47 AM
EvoulutionVIII's Avatar
well got my Utec installed and now i seem to have a lean running evo anyone know of setting to set fuel air ratio to to get the mixture right getting alot of ping now so back to map 0 till i can figure it out any help would be sweet
Old Jul 26, 2005 | 07:39 AM
sgplancer's Avatar
You need to list all of your mods before anyone can make an attempt to help.
You will also need to state what your target numbers (afr) are so that this adjustment can be stated as well.
FWIW I just did a global -6 adjustment and worked from there. Granted these are for my mods, and my method of tuning.
Old Jul 26, 2005 | 08:59 AM
BJai02's Avatar
You better tune it with a wideband.... it's been said enough. I have a Perrin boost tube with Apexi filter. I installed them at different time and I had to tune the fuel quite a bit to compensate the change in air velocity. And yes, it was big enough to cause lean conditions in some area and rich condition in different area because you will be traveling through some different load site than before. Good luck!
Old Jul 26, 2005 | 09:44 AM
sgplancer's Avatar
Very very off topic, but I am glad you said this. I have been fighting (mentally) with an issue I had with my new atp3071R. I could see that I was flowing more air as the hz increase by 400, but my afrs were running richer than before. Now I know why. Thanks for making my life better
Old Jul 26, 2005 | 01:12 PM
Well just got home from the tuner and she seems to be running quite abit better still getting a knock around 2500 at freeway speeds here is the mod list
Turbo XS RFL Catback Evo 8
Evo 8 Downpipe
CT9A Cat Delete Pipe
Perrin Red Evo 8 Intake
Perrin CEL Fix
Perrin EVO Boost Tubes Red
EVO TURBO XS UTEC
thanks now i need to get me a laptop so i can log and get the fine tune in on here and get rid of the knock im gettin
thanks
Old Jul 27, 2005 | 08:05 AM
BJai02's Avatar
if the AFR looks good from your dyno chart, try to retard timing in the area that you knock. But at 2500, most likely you were flooring it in 5th. The engine takes a lot of load when boosting up high at this low RPM range. If you don;t get knocks unless you flooring it, I would just leave it alone. Try to reatrd a degree or two if it bothers you too much.
Old Jul 27, 2005 | 12:46 PM
ok cool its like when in 5th gear and i want to pass a car between 2800-3300 rpm ill knock but it does not knock when i downshift to 4th and then pass a car so ill check timing but i think it might be fuel too since the perrin short ram gives so much air to the turbo and the boost tube seems to lean out the fuel mix maybe ill get this figured out or ill have to put on the factory air box and start over but thanks guys for the help on this matter
Old Jul 28, 2005 | 03:29 AM
at 2800 rpm to 3200 rpm at 30% throttle i get the knocks they seem to clear up with more throttle but ill be logging later tonight had to borrow a laptop from a friend to do this ill post the log tommorow night after i get home from work at 3:00 am PST you can let me know what i need to change then thanks in advance to any that helped me
Old Jul 28, 2005 | 05:48 AM
MalibuJack's Avatar
The boost curve in 5th gear is much different than lower gears, so you likely are ending up in cells that you may not typically have hit or tuned before.. Also, 30% throttle is just at the cusp of transitioning closed to open loop fueling, so making minor adjustments to the transition point, and the 10% column for your timing/fueling in the lower rpm load cells will help alot.
Old Jul 30, 2005 | 03:16 PM
ok question about tempature of when i tuned the car for all out 1/4 it was 80deg will i have to make a new map for when its 70 and 60 too or are those within the same heat tuning or what and ill have the log for ya to look at later tonight friend never came in with his laptop so ya can see whats going on when im in 5th gear and i get madd knocks
Old Jul 31, 2005 | 08:34 PM
MalibuJack's Avatar
Ya know, I run closed loop boost control and my AFR's are always pretty consistent so I never noticed what you guys experienced.. Or at least I never caught a huge difference.
lugging the car in 5th just seems to get knocking at times, and a bit of knock when shifting seems to happen to me occasionally.. Its really working with the lower load cells and timing..
Old Aug 8, 2005 | 05:05 PM
ok malibu ill look in to the looping when i get my laptop but till then i cant do anything till i can show ya some logs puter should show up tomorow (per UPS)
Old Aug 14, 2005 | 03:54 AM
DATA1
EXT Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF
psia Hz % deg duty deg % (OL) Hz
2834 +25.1 153 17 00 00 +37.6 5.8 ECU. +0.0 ECU. 144
2846 +25.1 148 17 00 00 +37.6 7.8 ECU. +0.0 ECU. 138
2832 +25.1 155 18 00 00 +37.6 8.0 ECU. +0.0 ECU. 154
2820 +25.3 171 19 00 00 +35.6 8.6 ECU. +0.0 ECU. 173
2836 +25.3 242 24 00 00 +28.4 10.9 ECU. +0.0 ECU. 244
2839 +25.3 272 26 00 00 +25.7 12.7 ECU. +0.0 ECU. 289
2841 +24.9 322 32 00 00 +20.7 13.8 ECU. +0.0 ECU. 327
2863 +25.1 378 35 10 00 +17.6 16.2 +14.4 +3.2 ECU. 403
2868 +24.9 421 40 10 00 +12.7 18.9 +14.3 +3.2 ECU. 410
2901 +25.1 467 43 10 00 +9.4 20.8 +14.3 +3.2 75.00 506
2903 +25.3 503 44 10 00 +7.6 22.9 +14.2 +3.3 75.00 559
2921 +25.1 554 45 10 00 +5.5 24.5 +14.2 +3.3 75.00 593
2949 +24.9 588 45 10 00 +4.3 25.8 +14.0 +3.4 75.00 631
2981 +24.9 626 46 10 00 +1.5 28.3 +13.9 +3.9 75.00 704
3024 +25.1 701 48 10 07 -7.3 31.3 +5.8 +3.5 75.00 730
3052 +25.3 742 48 10 00 -9.2 32.6 +5.7 +3.6 75.00 714
3097 +25.1 755 48 10 00 -9.2 33.0 +5.5 +3.6 75.00 796
3118 +25.1 723 45 10 00 -7.8 32.2 +5.4 +3.7 75.00 654
3124 +25.3 747 44 10 00 -6.1 34.9 +5.3 +3.8 75.00 651
3156 +25.1 748 45 10 00 -6.9 34.2 +13.2 +3.8 75.00 663
3205 +25.5 769 45 10 35 -8.8 34.2 +9.0 +3.9 75.00 791
3252 +25.5 776 45 20 06 -8.9 36.7 +2.9 +4.4 75.00 694
3287 +25.1 816 46 20 00 -9.8 36.4 +2.7 +4.0 75.00 825
3306 +24.9 809 47 20 00 -9.9 38.0 +2.6 +4.1 75.00 883
3330 +24.7 816 47 20 00 -10.0 33.7 +2.5 +4.1 75.00 791
3363 +24.5 789 46 20 00 -8.5 39.5 +2.4 +4.2 75.00 809
3415 +24.7 733 43 20 00 -7.3 37.8 +10.2 +4.3 75.00 746
3450 +24.9 673 40 20 00 -5.1 34.5 +10.0 +4.4 75.00 778
3494 +25.1 649 38 20 00 -4.8 30.8 +9.9 +4.9 ECU. 769
3523 +24.9 677 37 10 00 -3.7 31.3 +12.8 +4.5 ECU. 649
3531 +25.1 728 38 10 00 -4.7 34.4 +12.8 +4.5 ECU. 783
3553 +25.1 641 36 10 00 -4.4 27.9 +12.8 +4.6 ECU. 603
3584 +24.7 580 32 00 00 +1.6 30.1 ECU. +0.0 ECU. 548
3576 +24.7 411 28 00 00 +5.5 22.3 ECU. +0.0 ECU. 304
3599 +24.9 319 25 00 00 +14.7 14.1 ECU. +0.0 ECU. 258
3611 +25.3 162 18 00 00 +26.2 4.9 ECU. +0.0 ECU. 297
3595 +25.7 180 17 00 00 +37.1 6.2 ECU. +0.0 ECU. 159
3599 +25.7 100 12 00 00 +41.8 7.3 ECU. +0.0 ECU. 50
3568 +25.5 68 1 00 00 +35.8 4.6 ECU. +0.0 ECU. 107
3572 +25.3 66 0 00 00 +34.8 5.3 ECU. +0.0 ECU. 67
3557 +25.1 61 0 00 00 +23.7 4.9 ECU. +0.0 ECU. 67
3565 +25.1 43 0 00 00 +19.9 4.9 ECU. +0.0 ECU. 51
3516 +24.9 76 0 00 00 +25.8 4.9 ECU. +0.0 ECU. 73
3519 +24.9 74 0 00 00 +24.8 4.9 ECU. +0.0 ECU. 78
3508 +25.1 71 0 00 00 +25.8 4.9 ECU. +0.0 ECU. 70
3508 +25.1 69 0 00 00 +25.9 4.9 ECU. +0.0 ECU. 58
3483 +25.1 70 0 00 00 +24.8 4.9 ECU. +0.0 ECU. 74
3479 +25.3 64 0 00 00 +22.7 4.9 ECU. +0.0 ECU. 68
3454 +25.3 64 0 00 00 +21.6 4.9 ECU. +0.0 ECU. 62
ok sorry it took so long to get this to ya but fiannly
got my laptop anf was able to get the data posted
thanks for any help in advance
Old Aug 14, 2005 | 05:46 AM
MalibuJack's Avatar
Without knowing what boost or AFR the car is at that moment, its hard to tell.. But in both locations where you see knock, your timing map appears to jump at least 3 degrees or so, which is enough to trigger the knock sensor.. Looks like your going to have to try to smooth the timing a bit in those areas.
Old Aug 14, 2005 | 06:22 PM
DATA1
EXT Load Knock Mod Mod Mod30.5 9.1 ECU. +0.0 ECU. 231
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF31.7 9.6 ECU. +0.0 ECU. 208
psia Hz % deg duty deg % (OL) Hz31.7 10.2 ECU. +0.0 ECU. 221
3060 +25.1 173 19 00 00 +38.7 8.5 ECU. +0.0 ECU. 16231.7 11.5 ECU. +0.0 ECU. 225
3060 +25.1 176 19 00 00 +38.7 6
HOME MENU TURBOXS EVO-UTEC (Ver. 1.7) (c) 2004
3106 +24.9 228 21 00 00 +30.6 9.6 ECU. +0.0 EC
Key : Function
------------------------------------------------------------ +29.6 9.9 ECU. +0.0 ECU. 300
e or E : Edit Maps (Caps lock must be OFF) +25.3 237 22 00 00 +28.6 11.3 ECU. +
d or D : Dashboard
l or L : Logger
1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format) 241
r or R : Replay Last 25 Seconds of Data (Logger 1)2 ECU. +0.0 ECU. 246
Key : Function3.6 ECU. +0.0 ECU.
3097 +24.7 333 27 00 00 +23.6 13.2 ECU.
3129 +24.7
d or D : Dashboard4 14.7 ECU. +0.0 E
l or L : Logger
1 to 6 : Data Logger (<Shift - 1 to 6> : for .csv format) 00 +19.6 16.1 ECU. +0.0 ECU. 401
r or R : Replay Last 25 Seconds of Data (Logger 1)50 +24.7 392 28 00 00 +18.5 17.3 ECU. +0.0
DASHBOARD TURBOXS EVO-UTEC (Ver. 1.7) (c) 20048.5 17.2 ECU. +0.0 ECU. 416
Tacho : 3027 RPM
3192 +
MAP (EXT): +24.9 psi (absolute) ECU. +0.0 ECU. 503
MAF : 159 Hz
Knock : 00 counts/rev00 +9.4 24.6 ECU. +0.0 ECU
SES/MIL : OFF
MODE : MAP 1 Switch : 1 00 00 +6.6 26.6 ECU. +0.0 ECU. 605
Modifications
Ignition : ECU. degrees Fuelling : +0.0 % change13.0 +3.9 ECU. 647
Boost : ECU. % (open loop) Injector : 550 (Stock 550) +4.0 ECU. 681
Launch : OFF Knock : --- 28.6 +8.8 +4.0 ECU. 645
<CTRL-x> : Exit to Main <p> : Pause <s> : Start <space> : Toggle 29.2 +8.8 +4.1 ECU. 688
3320 +24.9 680 37 10
Key : Function+8.8 +4.1 ECU. 75
3367 +25.1 677 37 10 00 -5.5 30.0 +8.8 +4.1
d or D : Das
3360 +25.1 610 35 10
Tacho : 2973 RPM TPS : 20 %
Timing #1: +31.6 degrees before TDC Coolant : 87 degrees C
Inject #1: 11.0 % Air Temp : 38 degrees C
MAP (EXT): +24.7 psi (absolute)
MAF : 215 Hz
SES/MIL : OFF
Modifications
Spare Sol: OFF Mod. MAF : 222 Hz
Correct. : OFF Load Site: 00 %
ok here is maybe the stuff ya are asking for
