MPS_UTEClogger 2.3
Old Dec 4, 2005 | 07:41 PM
  #76
Nesiop's Avatar
Any word on the PLX R-500 yet?
PLXDevices.com
Old Dec 5, 2005 | 08:40 AM
  #77
jmussetter's Avatar
Not yet, this is the busy time of year for me, work wise, and I havn't had time to add any new stuff in awhile. I'm hoping things will slow down a bit after the new year, and I can work on the logger some more.
-jason
Old Dec 31, 2005 | 05:46 PM
  #78
35Ounces's Avatar
Originally Posted by jmussetter
Everything in their manual indicates that the AEM guage only reads down to 11.0:1 and no lower.
However, I don't own and AEM and couldn't confirm this when I added this to the program. If you can connect to the AEM from HyperTerm and log AFR's lower than 11:1, then let me know and I will fix the issue in the logging program.
-jason
The old AEM gauges read to 11:1, the new gauges read below that (to 10 I believe).
I'd like to see your program work with the new Z-Utec
Old Jan 1, 2006 | 01:54 PM
  #79
STIEater's Avatar
During the whole time that i`m driving... the Boost gauge on UTEClogger reads anywhere from 24.9-25.7 , this is on stock map and idle speeds or 110mph , always reads between 24.9-25.7 lbs of boost... any ideas? I don`t have a boost gauge in my car.. but either way... that is NOT possible lol. Any help?
Old Jan 2, 2006 | 12:39 AM
  #80
mike1023's Avatar
humm do you have a map sensor and if so calobrat it woot woot
Old Jan 2, 2006 | 03:01 AM
  #81
WarmPepsi's Avatar
haha, yeah, you need a map sensor.
i actually bought one, but haven't installed it yet. I assume the best place would be in the link from the manifold to the bov/boost controller?
Old Jan 2, 2006 | 08:28 AM
  #82
blink2824's Avatar
Thanks for all of the updates Jason. I am getting ready to install the UTEC myself and am looking forward to using your program. Thanks again...subscribed.
,Tyler
Old Jan 5, 2006 | 09:06 AM
  #83
Nesiop's Avatar
Bump on the PLX Devices R-500.
Old Jan 6, 2006 | 11:22 AM
  #84
Nesiop's Avatar
Could someone take a picture of how they hooked up there AEM wideband to there laptop to work wih the UTEC/MPS Logger
Old Jan 14, 2006 | 09:58 PM
  #85
Nesiop's Avatar
Bump...
Old Jan 16, 2006 | 08:20 AM
  #86
Nez136's Avatar
I'll see if i can snap a shot today, im just using a camera phone. With the AEM i made my own plug-n-play for the laptop. Everything i used is From Radio Shack. 2 wires of any color choice as long as you can tell the difference, 1 custom do-it-yourself serial connector, and a soldering iron. I had to also buy a Serial-to-USB adapter b/c most laptops don't have more than 1 serial port. My Utec is hooked up through the USB and the Wideband through the Serial port on the PC. The AEM has 1 random blue wire hanging of that is the Serial output(stupid why they could just make their own adapter) which is to be connected to the custom serial connector (Soldering Iron). Then you just ground out the other wire that comes out of your serial connector.
I can post a diagram if you want but otherwise i'll try to get picks ASAP
Old Jan 16, 2006 | 03:49 PM
  #87
Nesiop's Avatar
I think I get the idea but yeah a diagram and pics would be great bro.
Old Jan 17, 2006 | 09:32 AM
  #88
Nez136's Avatar
Okay, so the pictures did not turn out good at all (camera phone), but here goes nothing...
Picture 1, The Back of my PC with 1 serial port. 2 USB ports
Picture 2, The Custom Female serial connector i made containing 2 wires, 1 connected to the blue serial wire off the AEM UEGO and the other is a ground. inside the Serial connector there are 9 little prongs for data transfer and ect. I believe you have to solder the blue wire to #2 on the connector and the ground to #7
\ 5 4 3 2 1 /
\ 9 8 7 6 /
Pin | Name | Description
Orange 2 | TD | Transmit Data
Black 3 | RD | Receive Data
Red 4 | RTS | Request To Send
Green 5 | CTS | Clear To Send
Brown 7 | SG | Signal Ground
White 8 | DCD | Data Carrier Detect
Blue 9 | DTR | Data Terminal Ready
Picture 3, The Serial cable from the Utec is now connected to the Serial-to-USB adapter ($30-$40 depending on where you buy it)
Picture 4, Ther Other side of the Serial-to-USB adapter
Picture 5, Both the USB and Serial connectors are on the PC and ready to go, make sure you figure out what COM ports you need to select on your PC.
Click on Pictures to Enlarge with a brief discription
Attached Thumbnails MPS_UTEClogger 2.3-picture-001.jpg   MPS_UTEClogger 2.3-picture-002.jpg   MPS_UTEClogger 2.3-picture-003.jpg   MPS_UTEClogger 2.3-picture-004.jpg   MPS_UTEClogger 2.3-picture-005.jpg
Old Jan 17, 2006 | 03:45 PM
  #89
Nesiop's Avatar
Great writeup, just didn't need some pics haha, I am a compuer tech.
So I will get a serial adapter at radioshack and leave all the pins exposed except solder pin 2 and the blue wire from the AEM and the other AEM wire is the ground to go to pin #7?
Old Jan 18, 2006 | 08:58 AM
  #90
Nez136's Avatar
AEM Emailed me the pinouts a while ago but i deleted it, you might want to call them and Double check, but im pretty sure thats correct
