Nitrous and Utec?
Old Aug 6, 2005 | 02:08 PM
2.3EVO8's Avatar
Nitrous and Utec?
I just got a zex wet kit to help spool my turbo on the drag strip. In the direction is says that you can't run a "Chip" in the ECU because it adds timing, and if anything you should pull timing. So if just pulled a little timing of my normal map would i be ok?
Old Aug 7, 2005 | 05:34 AM
MalibuJack's Avatar
Well, I don't run nitrous in my car, but tuning nitrous is just like tuning for higher boost, so pulling a little timing is what you would normally do. Since I don't use nitrous, I don't have any real guidelines or suggestions. It may also not be necessary to remove timing in some circumstances.
Remember, the nitrous kits are usually generic so their instructions are for the typical install. You will have to tune for this though obviously.
Old Aug 7, 2005 | 12:31 PM
2.3EVO8's Avatar
Thats what i thought, i will for sure be on a dyno the first time i spray. Thanks for your help!
Old Aug 16, 2005 | 03:01 PM
TwStDeVo's Avatar
im thinking about doing the same thing. what are the risks to running nitrous with the utec? better yet with the evo? i can probably guess why you want to do this....ELEVATION SUCKS!!!!
i am having the same problem. i want to get a gt35r kit but it will probably spool like crap at our elevation. i dont know what to do, either try the kit with nitrous or stick with something alot smaller like the buschur 20g.
Old Aug 16, 2005 | 03:08 PM
2.3EVO8's Avatar
I hate being a mile high! i
Old Aug 16, 2005 | 03:09 PM
TwStDeVo's Avatar
have you decided on what you are going to do? if have aol, contact me: twstdm3
Old Aug 17, 2005 | 08:04 PM
TwStDeVo's Avatar
bump
BGM3
Dec 7, 2010 01:41 PM
AcePitcher11
Aug 9, 2009 07:52 PM
rACerS
20
Apr 14, 2009 08:01 PM
JTB
Apr 4, 2005 02:45 PM
mooreboost
Mar 27, 2005 02:12 PM
