UTEC not displaying any numbers in Knock column
Do I need to have the tuner hooked up to detect knock or does the UTEC use the ECU wiring harness to connect to the knock sensor. I feel like I should be getting zeros in my Knock column at least, assuming everything is hooked up right. I guess I am somewhat paniced since we have 91 oct. gass here and I didn't get any knock with TurboXS's Stage 1 map. But the exhaust note sounded significantly different.
My UTEC is not showing any Knock in the knock column. Does this mean I don't have any, or is something wrong?
