safc2 solution for EIDS
Old Aug 10, 2005 | 02:13 PM
grico42's Avatar
I have an 03 evo and like most 03's if i turn the air conditioning on or go from high to low rpms really fast i stall. I have been thinking about purchasing EIDS to solve this problem. However i was wondering if tweaking with the idle on a SAFC if that would accomplish the same effect. Anyone know if this will work?
Old Aug 10, 2005 | 05:13 PM
jmartinez1170's Avatar
i have that same setup u got and that hks edis will help with the a/c as much it will help the car from dieing on you but if you got cams it wont help u keep idel up. just get a reflash and redo the a/c fan speed and get some type of grounding kit.
Old Aug 11, 2005 | 06:48 PM
grico42's Avatar
i dont have cams, i have tried a grounding kit but i didnt notice anything. Flashes are okay but i i know alot of people like the SAFC2 as well as myself. Also how would i redo the a/c fan speed. I have never heard of anyone doing this.
Anyone with a AFC2 corrected this problem??
Old Aug 13, 2005 | 04:35 PM
grico42's Avatar
ok then, can a EIDS and SAFC be run together? or will the buffing or the air signal screw up the SAFC signal?
Old Feb 20, 2006 | 06:26 PM
Sweaty Balls's Avatar
Did you get any answers to your questions?
Old Feb 28, 2006 | 04:04 AM
trinydex's Avatar
they can work together but supposedly the safc ii is suppose to do it itself... however i think they just mean giving it a bump in fuel down low.
Old Mar 7, 2006 | 06:19 AM
RyanM's Avatar
You can run the SAFC and the EIDS together. I am. The SAFC functionality that is supposed to work like the EIDS does not work. I tried this to start out with and quickly purchased the EIDS unit. EIDS does its job very well.
Old Mar 7, 2006 | 06:26 AM
Silvercar's Avatar
Its not good to run these to together they interfer to much with siglnals to the ECU one or the other to b safe.. The SAFCII is not good for a idle fix on the Evo go with the EIDS if you just worryed about simple things like if you want to VTA.
Old Mar 7, 2006 | 10:15 AM
RyanM's Avatar
I've run them both in conjunction for 25K miles with no issues. These devices adjust the voltage of the signal on wire which the ECU detects as the air/fuel ratio from the MAF and the throttle signal. If either device was screwing up the voltage my car would not run at all or would run terribly.
The EIDS has a very simple process for what it does, when you let off the throttle, it simulates a signal. You can actually see the value on the SAFC as 1-2% throttle indication (if you increase or decrease the EIDS settings it will vary this voltage).
evo_assault
Jan 4, 2008 07:27 AM
kaonashi
May 16, 2006 05:13 PM
Soon2BEVO
May 24, 2005 04:04 AM
EVO316
14
Oct 3, 2004 08:30 PM
Technoz
Aug 6, 2004 06:01 AM
