Downpipe? ... next step in mod? help...
Old Aug 17, 2005 | 12:12 PM
HezEVO?'s Avatar
i have a 2004 evo, with an RMR intake, 3" Nvidia exhaust & greddy turbo timer, the guys from the NTevo owners club (evotexas.org) said my next step should probably be a downpipe, or downpipe+hi flow cat? will this add a significant amount of power? also, there are about 1million different downpipes available, ranging from $100-$400 or more.
whats the difference?
which do you recommend? price/performance wise.
thanks
hez
Old Aug 17, 2005 | 03:14 PM
05WhiteEVO8's Avatar
Just think of a downpipe as a bigger pipe let air get out of the turbo quicker, you will gain some power by putting one on. In my opinion the only difference is price and since you do not have an 05 fitment should not be an issue. Get the cheapest three inch you can.
Old Aug 17, 2005 | 03:24 PM
nutrulz's Avatar
All downpipes are not created equal. Some "3 inch" DPs start smaller to match the o2 housing. These are not true 3". Some Taper at the Cat. You need to know if you are going to go with an aftermarket 3" O2 housing, if you are going to remove the CAT or not. These answers will make a big difference.
Old Aug 22, 2005 | 02:07 PM
EVIL_EV0's Avatar
The down pipe is about useless unless you shed that cat....the cat is still the bottleneck.
Turbo cars should be modded from the tailpipe forward.
I purchased a megan exhaust , testpipe, and downpipe from Zeus. I put on the cat back first then a week later installed the DP and testpipe. The biggest gain I felt was in spool and then power above 6k .....midrange felt the same.
ticket_target
Evo X Dyno Results
12
Jun 20, 2015 12:22 AM
ahendrickson
Evo X How Tos / Installations
Apr 16, 2013 05:58 AM
crcain
48
Apr 14, 2009 09:51 AM
jd888jd
12
Mar 16, 2009 03:09 PM
midnightsuns
10
Sep 20, 2005 09:05 AM
