TurboXS KnockLite
Old Aug 19, 2005 | 04:57 PM
EVO8LTW's Avatar
TurboXS KnockLite
Anyone have one of these?
The CEL light is not very useful for seeing knock during the daytime. Anyone know if something like this would be easy to use with the Evo or whether it can interface with the UTEC?
Old Aug 29, 2005 | 11:39 PM
edwin's Avatar
I just put one in my car. I dont know how sensitivity I need to set at. but i know theres 10 levels that i can always change. its cool that it come with shift lite.
Old Aug 30, 2005 | 03:55 AM
EVO8LTW's Avatar
Are you using it with the stock knock sensor? How does it connect? Do you just tap the wire off the ECU harness?
Have you been able to get a sense for how it works yet?
Thanks.
Old Aug 30, 2005 | 12:55 PM
edwin's Avatar
yes I using the stock knock sensor. connect to ECU harness. yes i konw how it work...
Old Aug 31, 2005 | 04:05 AM
edwin's Avatar
anybody know how sensitive i need to go on the Knocklite for the EVO?
Old Sep 1, 2005 | 08:07 AM
Imprezd's Avatar
The Knocklite has a algorithm for setting the knock thresholds when installed correctly. You must connect the rpm signal for it to work correctly.
I would follow the knock threshold procedure. Then adjust the sensitivity after driving around making sure that it doesn't flash over actively. As you should know if it is over active it might as well not work at all.
Thanks,
Jermaine
Old Dec 31, 2005 | 03:32 PM
HxllxMan's Avatar
Does it required the Turbo XS or just tap to the ECU?
Need more feedback about that product... Anyone?
Old Jan 5, 2006 | 08:24 AM
STREET CONCEPTS's Avatar
You can run the knock lite without the utec. You just wire is directly to the factory ecu harness. It is very easy to install only takes 30min to an Hour. The product has worked great for us so far.
Old Jan 27, 2006 | 09:31 PM
Cloud's Avatar
Someone said there is 10 levels of sesitivity. What level are you running yours at?
I'm pretty interested in this product. Thanks for your response.
csra09
Sep 20, 2011 07:43 AM
Mishi9
Oct 7, 2010 05:41 AM
Bob_tm
Evo X How Tos / Installations
Jul 13, 2009 08:05 AM
Imprezd
16
Sep 22, 2004 05:20 PM
nmyeti
Apr 4, 2004 10:29 AM
