Which Engine Management 2 go with?
Old Sep 23, 2005 | 06:48 AM
  #31
gt420hp's Avatar
I just download the tune maps from Vishnu's website. I have been using their stages as I progress. My next jump is to go to the V390 stage (includes cams, cam gears, and fuel pump upgrades).
If I wanted to mess with it...I could, but I don't know enough about it. Thats what I like about the Xede. I can tune it myself, or use the various stage maps. I think to truly tune a car, you need access to a dyno. Or...spend a lot of time at the track making run after run after run.
Old Sep 24, 2005 | 10:53 AM
  #32
ez's Avatar
ez
Originally Posted by KGParts
http://www.microtechefi.com
we use them on rotaries with great results.
...found review of the Microtech
http://www.airpowersystems.com.au/wr...tech_MY98.html
Old Sep 24, 2005 | 11:42 AM
  #33
forum04pl's Avatar
ive been hearing alot of good things about ecu+ lately you should check them out and see if that is something that would work for what you want to do
Old Sep 24, 2005 | 05:29 PM
  #34
slushfund's Avatar
I'm learning alot on this thread.
Not ramble too much, but my first EVO experiance was in Winchester, UK. I was there on business and I saw an EVO 6.5 TME in the parking lot. I had one ride and was hooked. James still owns the TME. I emailed James on this very question.
James says Motec is big bucks and thats what he uses. He calls it "Plug and Play". James initially had a tuner setup his TME, but over time has taken on all tuning. He is very satisfied with Motec.
I found out the EVO 8 plug and play board is under development for USDM EVO's.
Does anyone have hands on experiance with the Motec EVO 8 Plug and Play boards?
Old Sep 24, 2005 | 05:40 PM
  #35
nothere's Avatar
no idea on the Motec, I can tell you the Hydra is great fun fiddling with. check it out, although Phil (Element) has focused on the Subby group, he sells/ tunes Evos emu too.
http://www.elementtuning.com/main.htm
Old Sep 25, 2005 | 06:26 PM
  #36
evotino's Avatar
I recommend choosing from what your local shops will support. If you ever have problems you'll appreciate the ability to take your car to somebody local that will fix it.
Old Sep 25, 2005 | 06:30 PM
  #37
sdhotwn's Avatar
Except that if it actually has a problem that is serious you wouldn't be able to get it to the shop. I'd personally rather have something I fully understand and can fix than something I have to leave to someone else... but if you really don't think you are capable.. then the local shop is better.
Old Sep 25, 2005 | 06:54 PM
  #38
slushfund's Avatar
Checked out Hydra Nemesis.
The documentation seems to be thorough. $1450.00 plus a lamda UEGO.
Check it out; http://www.hydraems.com/home/
