PO300 code problem
Old Sep 5, 2005 | 05:25 PM
unknown2's Avatar
PO300 code problem
I have an 05 EVO and it has a flash just wondering if anyone else has ran into this problem yet. The ecu keeps throwing a misfire code just when im at idle i keep clearing it but it keeps coming back. Do you guy think it could be something with the flash.
Thanks for the help in advance.
Old Sep 7, 2005 | 05:49 AM
locam's Avatar
I had a the same problem when I got my reflash, and I couldnt get it to go away. I had the ecu pulled out of the car for a few days while I was being tuned for my standalone. Ran into some problems with the EMS and had the factory ecu put back in till the EMS was fixed. Ever since I have not had the code shop up. A lot of times when your idle is adjusted it messes with the idle air controll stepper vale (IIRC). Sounds like that needs to be reset then your problem should go away.
caelin~
Old Sep 9, 2005 | 12:24 PM
fsugatorbait's Avatar
caelin~
How would you go about that? Im having the same miss fire code after cams and custom tuning by TT.
shadovarian
Jul 14, 2013 01:21 PM
lil' jeff
Lancer Engine Tech
11
Jan 12, 2011 06:29 AM
Werd
Jun 6, 2010 08:04 AM
Fp3052
Jan 25, 2007 04:05 PM
