Is my UTEC strange?
Old Oct 1, 2005 | 07:32 AM
joeymia's Avatar
Originally Posted by Widebandphillip
What's wrong with the mps logger? .
That I always hit open log without change the log name. The new release will fix that!
Old Oct 2, 2005 | 10:42 AM
Widebandphillip's Avatar
Originally Posted by WarmPepsi
joey, what gear are you logging in, 3rd?
i only ask because after seeing philip's logs, your load sites are at 100 like instantly. You're at 100 load below 5000, whereas phil hasn't hit 100, and i don't hit it at 7k @ 18 psi.
Whats the reason for that?
I believe it's because he's got 280's and the WR, and i have a stock cammed stock turbo car.
edit: cancel on the WR, coulda sworn he had one.
Old Oct 2, 2005 | 10:51 AM
WarmPepsi's Avatar
i gotcha, thanks.
Old Oct 2, 2005 | 11:08 AM
joeymia's Avatar
I did most of those logs while in 4th gear. I would slow down to like 35-40 and punch it. I live near the turnpike so I just go out at night and do a few runs.
Old Oct 2, 2005 | 11:09 AM
WarmPepsi's Avatar
ahhh, i gotcha.
Old Oct 2, 2005 | 11:18 AM
EVO8LTW's Avatar
joeymia, your airflow numbers are really high for the boost pressure in the log. Is that the correct boost?
Old Oct 2, 2005 | 08:06 PM
dryad001's Avatar
Same thing I was thinking. I hit right below 2000hz with a WR.
Might want to check and see if you have a boost leak. I had the same hz's before I found 3 leaks, 1 of them was a seam leak in the IC.
Old Oct 2, 2005 | 08:47 PM
joeymia's Avatar
you guys are right I have to have a leak somewhere. few weeks ago i tested my entire system for over 30 psi. i have to have sprung a leak somewhere. high maf is probally why I have remove so much few as well.
Old Oct 2, 2005 | 08:49 PM
Or you could have a freak of a car *_-
fostytou
359
Oct 23, 2025 09:54 AM
Complink
Lancer Engine Management / Tuning Forums
277
Jul 23, 2016 05:47 AM
Blue91lx
Aug 14, 2014 02:50 PM
joseph143
Feb 19, 2014 07:42 AM
Heezayx
Sep 17, 2013 04:25 PM
