safc-II vs. Flash
Old Oct 16, 2005 | 05:37 AM
MuslimEvoFreak's Avatar
Question safc-II vs. Flash
Hey guys, Im a little confused on whether I should get a flash or an SAFC-II?? Any suggestions??
Old Oct 16, 2005 | 05:43 AM
Talon's Avatar
I have wondered the same thing. Seems a flash would be good, but if you continue to mod, are you going to have to flash the ecu again and again? For about the same price as one flash, you could just get an AFC, then dyno tune it in the future for much cheaper... not to mention you will get some dyno runs in.
Old Oct 16, 2005 | 05:54 AM
PapitoEVO8's Avatar
Well, I might be wrong but you will need a flash to remove the the limits that the ecu has. And then the SAFC II to tune all your mods
Old Oct 16, 2005 | 08:24 PM
EVILutionVIII's Avatar
Veteran: Air Force
This is true. Without the flash, chances are you will fall short becuase of the rev limiter
Old Oct 18, 2005 | 06:32 AM
AutobonEvo's Avatar
guys go with ecu plus...safc II is good but you cant control timing and it has limited options, with the flash every time you get a new mod you have to get it retuned or pay a $50 mail in flash. With ecu plus you can control timing a/f, get you 1/4 mile 0 -60, and a millions other things you can data log with your labtop and tune on the go. I just purchased it and got 25-30 more horse then a flash. www.ecuplus.com
Old Oct 18, 2005 | 07:31 AM
akunochi's Avatar
I really like that ECU+ I think I may look into getting one....
Is it fairly easy to learn to tune it myself if I am a fairly smart guy with the right equipment and access to a drag strip?
Old Oct 18, 2005 | 07:35 AM
AutobonEvo's Avatar
yeah you dont even need to be smart its idoit proof. You dont need a drag strip either you just need a straight road with no police. Another feature i forgot that i really like that it has is a build in dyno, so you can see what kind of number your putting out.
Old Oct 18, 2005 | 07:37 AM
warp9's Avatar
best advice
Old Oct 18, 2005 | 07:39 AM
AutobonEvo's Avatar
or just not spend that much money and pay have for one system that does all that and more.
Old Oct 18, 2005 | 07:41 AM
akunochi's Avatar
SO my best bet would be a preliminary flash from like dyno flash to support bigger injectors for the GT3076 RNR turbo package and remove the rev limiter and an ECU+ for tuning? At least that's what I gathered from the site am I wrong?
Oh sorry about hijacking the thread. THE SAFC-II netted my buddy some good power in his 03 Evo, but they are right you will still need a flash to use it properly.
Old Oct 18, 2005 | 07:43 AM
AutobonEvo's Avatar
im pretty sure on ecuplus there coming out with being able to set your own rev limiter and having a studder box to your setting.
Old Oct 22, 2005 | 07:17 AM
Thanx guys for the replies, so I should first get a flash and then an SAFC-II to get power more power out of the mods.
Old Oct 24, 2005 | 12:03 AM
GDB's Avatar
GDB
If you read the entire thread replies, I think you'd realize by now that ECU+ is the way to go instead.
Old Oct 24, 2005 | 04:17 AM
I know that, but an ECU costs an upwards of $1000 and I don't have that much money but a flash from dynoflash for $200 and SAFC-II for $275 and I'm good to go.
Old Oct 24, 2005 | 05:03 AM
GDB's Avatar
GDB
If you read the entire thread replies, you'd realize by now that we are talking about ECU+, not ECU in general.
www.ecuplus.com
$600 I think or around there.
RallliartEVO6
20
Sep 10, 2007 09:10 AM
Forevapmp
Feb 10, 2007 01:26 PM
03BREvo8
Feb 3, 2005 08:39 PM
StockC5
Jan 3, 2004 11:20 PM
webguy330i
Sep 18, 2003 07:37 PM
