05MR w/exhaust and MBC set at 20psi
Old Nov 19, 2005 | 11:06 PM
  #31
EVO MR FU's Avatar
I upped the sampling rate, and now I have alot more info to work with!
I started over again and used less aggressive settings, highest currently is at -7%
I can't seem to totally eliminate timming getting pulled just a little bit usually occurs around 4k or 5k , but I think these are pretty stable..
Im not really quite sure how to make a absolute perfect timing curv,
even with AFC set at 0, i still had small timing pulled from like 6-5 at around 4k.
heres the runs
last run
RPM TIM 02
3078 7 .90
3156 6 .92
3296 5 .92
3371 3 .92
3519 1 .94
3683 3 .94
3769 4 .94
3925 3 .94
4074 4 .94
4207 5 .94
4351 5 .94
4476 6 .94
4625 6 .94
4753 7 .94
4886 7 .94
5027 8 .94
5175 8 .94
5273 8 .94
5410 8 .94
5515 8 .94
5652 8 .94
5785 9 .94
5910 10 .96
6015 13 .96
6128 13 .94
6234 14 .94
6351 14 .96
6460 16 .96
6578 16 .96
6683 17 .96
6769 17 .96
6867 19 .96
6984 19 .96
7070 21 .96
7148 21 .96
7226 22 .96
7308 22 .96
7410 22 .96
Old Nov 20, 2005 | 06:28 AM
  #32
Itsmeeeugene's Avatar
you can definately get into the .93 range in the mid to high end range. mine goes like .92-.93 all the way across the rpm's.
Old Nov 20, 2005 | 10:17 AM
  #33
RazorLab's Avatar
Please don't tune like that. I have .94 on my narrowband and the wideband reads 11.4 afr
Just think about that for a second. If you are going to tune via only narrowband, please be conservative.
mak1000
Apr 17, 2014 05:11 PM
korizmo
Nov 4, 2012 05:19 PM
evil_evo
For Sale - Cars For Sale
26
Jun 14, 2011 03:27 AM
deadbeatrec
69
Nov 7, 2006 11:51 AM
525iT_Feen
West Region
10
Feb 15, 2005 12:49 PM
