ECU+ and Zeiotronix?
Old Nov 12, 2005 | 07:11 PM
akunochi's Avatar
The Zeiotronix(sp?) wideband is supported, but if I already have the boost and EGT sensor for teh LCD display, will it still wire up to the ECU+. Will teh ECU+ take teh EGT data logging directly from teh Zeitronix like it does teh AFR?
Old Nov 15, 2005 | 07:15 AM
Ev0ikon's Avatar
Bump for an answer :}
Old Nov 15, 2005 | 06:52 PM
tlcoll1's Avatar
As far as I can tell, the answer is no to both. Zeitronix has only made the AFR output usable with other systems. The EGT wire is the direct output of the EGT sensor, and you can't "tap" that due to how it works. Not sure about the MAP sensor. That might work if Zeitronix would release the curve for it.
Tom
Old Nov 15, 2005 | 07:36 PM
akunochi's Avatar
So how does teh ECU+ recieve EGT temps for logging, if at all?
Old Nov 15, 2005 | 07:59 PM
tlcoll1's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=168578
Tom
akasirlancerlot
Lancer Engine Tech
18
Jan 6, 2006 03:00 PM
akasirlancerlot
Apr 5, 2005 01:11 PM
jasonn
Jan 20, 2004 05:50 PM
RedEvo6
Site Feedback / Suggestions
Sep 25, 2002 11:09 AM
