280 cam question
Old Nov 19, 2005 | 10:08 AM
VIIImylunch's Avatar
280 cam question
How much vacum pressure are you guys seeing at idle with the 280s?
Old Nov 19, 2005 | 10:20 AM
spyonu2007's Avatar
I see about -15lbs average, as low as -18 and as high as -10 (due to this idle surge issue I've developed)
Cam gears are set at 0.
Old Nov 19, 2005 | 10:26 AM
djskyy's Avatar
-10 thru -15 here......
Old Nov 19, 2005 | 10:28 AM
For some reason at idle it making -5 to -9. I m on the stock turbo. Any suggestions I am on the stock cam gears.
Old Nov 19, 2005 | 10:48 AM
spyonu2007's Avatar
I would boost/vacume leak check her.
Old Nov 19, 2005 | 01:00 PM
Ultimate CC's Avatar
Yea definitely sounds like theres a leak somewhere
Old Nov 19, 2005 | 09:37 PM
When I get on the gas the vacuum presure drops to -15 to -20, but at idle it is only at -9. I cant figure out where a leak would be comming from.
Old Nov 21, 2005 | 07:11 PM
What sort of timming and fuel are you guys running in order get these cams idle? Also when I start at low rpms the downpipe rattles alot what do I need to do in order to fix this?
Old Nov 22, 2005 | 10:07 AM
anyone?
tbaird58
Feb 21, 2017 06:13 PM
Jeff_Jeske
Oct 10, 2014 12:21 PM
ninja808
South Region
Apr 18, 2008 06:03 AM
APEX1
May 9, 2007 10:05 AM
EvOcHaRgeR
GSC Motorsports - Charleston, SC
29
Jan 9, 2007 11:04 AM
