UTEC Launch Control Question
Old Nov 29, 2005 | 02:20 AM
joeymia's Avatar
Hello I recently converted over to a MSD-2 ignition system. I loved how the UTEC launch control worked but unfortunally I don't have any logs to see how it really worked. Can some please provide me logs to see the fuel and ignition values. I am currently getting about 6-8psi with my setup with no ignition retard. If I retard the ignition a few degrees I get about 12psi. My goal is to setup a "poor mans" anti-lag system
Here is a clip of the car running the launch control with no ignition retard:
http://72.41.83.159/video/msd-lc-noretard.wmv
Here are some pictures for those interested on how it looks:
Old Nov 29, 2005 | 06:34 AM
sleet's Avatar
I can get you some logs, just gotta tell me exactly what you want
Old Nov 29, 2005 | 09:58 AM
joeymia's Avatar
turn your launch control on and let it bounce off the 5k rev limiter. I just want to see how much timing they are using.
Old Nov 29, 2005 | 07:48 PM
sleet's Avatar
Can you give me a good logger? All the ones I got are crap.
Old Nov 29, 2005 | 07:58 PM
Nesiop's Avatar
Use the UTECS logger. Shift F1.
Old Nov 30, 2005 | 07:49 AM
sleet's Avatar
^ I know that one, but there's gotta be a better one.
Old Dec 2, 2005 | 06:33 PM
TrinaBabe's Avatar
If you have the capability I would start around 10 degrees AFTER top dead center... or -10 degrees depending on how you look at it. That should give you good bursts out the back of the car and full spool a decent size turbo within a few seconds.
Old Dec 4, 2005 | 03:51 PM
joeymia's Avatar
I did -15 the other day and it sounded like gun shots Also screwed up a nice set of plugs hehe
Old Sep 18, 2006 | 06:16 PM
dubbleugly01's Avatar
To bring a thread back from the dead....
I noticed in the vid that the a/f went really lean during launch control. I was playing around with mine tonight in the garage, and it did the same thing, went up to 25:1.
My question, if you use the ignition cut (vs. fuel cut) for launch control, shouldn't it run rich when you're bouncing off the launch control rev. limite??? I used ignition cut, but I'm not sure what joeymia used in the video, it's not stated in this thread.
Wow, this forum is dead....... the only posts you get are me asking newb questions and others trying to sell their utec. I'm always late to the party.
joeymia
88
Dec 20, 2009 06:30 AM
joeymia
86
Sep 10, 2008 02:39 PM
joeymia
120
Apr 14, 2007 06:32 PM
joeymia
Feb 11, 2006 10:33 AM
joeymia
Dec 22, 2005 08:59 PM
